Member and Staff Blogs Peek inside an SMD Ethernet transformer
  • Date Created: 18 Jul 2020 6:30 PM Date Created
  • Views 3227 views
  • Comments 8 comments
  • smd
  • ethernet
  • magnetics
  • transformer
18 Jul 2020
On many Ethernet devices, you find magnetics - a transformer - as part of the physical layer.
The example above is from a TI TM4C launchpad. It looks like a solid block - like a silicon package.
I have a defect launchpad so I scavenged some parts.
To my surprise, this is how the transformer looks like from the underside:
Surprisingly old school.
Supplier's schematic: Pulse HX1198FNL
  • Andrew J
    Andrew J over 6 years ago +2
    It looks Heath Robinson!
    Jan Cumps over 6 years ago in reply to Gough Lui +2
    Gough Lui wrote: I'm surprised this one wasn't covered in potting compound / resin, as most of them seem to be. - Gough The coils seem to be glued in. They are fixed on the spot. But no potting.
  • colporteur
    colporteur over 6 years ago +2
    I'm curious after reading your post. That must be what is under the Ethernet canister hood of the Pi. I don't have a failed Pi to put under the knife to have a look, so I will just imagine. The theory…
  • Gough Lui
    Gough Lui over 6 years ago in reply to colporteur +2
    In the case of the Pi, it is integrated into the RJ45-style jack housing - hence why those are known as "MagJacks". Curiously enough, the Ethernet on the first batches of Pi was non-functional purely because…
  • Gough Lui
    Gough Lui over 6 years ago +1
  • Fred27
    Fred27 over 6 years ago +1
    I know that's what's inside but it just doesn't seem that something so simple would be capable of handling data at gigabit Ethernet speeds.
    Jan Cumps over 6 years ago in reply to Fred27 +1
    This one This one is spec'd for 100 Base
    DAB over 6 years ago
    Good post Jan.
    This oneThis one is spec'd for 100 Base
  • Fred27
  • Gough Lui
    Curiously enough, the Ethernet on the first batches of Pi was non-functional purely because the factory substituted "plain" jacks instead of jacks with integrated magnetics. There are some X-ray shots in the blog that show the difference.
    - Gough
  • colporteur
    The theory of electronic and how things work moves to the back of my thinking for the most part. It is fascinating to actually explore the physical of the electronics that make the theory reality. Great find JC, thanks for sharing. Stuff like this is what made electronics exciting in the first place.
