Member and Staff Blogs Repurposing broken e-reader into a Sudoku machine ⛓︎‍
  • Author Author: 91Raindrops
  • Date Created: 6 Nov 2026 10:55 PM Date Created
  • Views 27 views
  • Likes 12 likes
  • Comments 13 comments
  • e-reader
  • claude
  • ai
  • repurposing
91Raindrops
91Raindrops
6 Nov 2026
An e-reader with only part of its screen still working now runs Sudoku, a clock, a battery level and a warm pulsing light.
Don't throw it away: how a broken e-reader became a tiny Sudoku machine
My e-reader's screen was broken. Most of it stayed frozen on its last image, with lines running through it. By any normal measure it was e-waste. One afternoon later, the part that still works plays Sudoku.
Before: most of the screen is frozen, and only the bottom part still redraws.
What it does now
  • Sudoku with Easy, Medium and Hard puzzles, a score, hints and a saved game
  • A clock and battery level on a second working patch of screen
  • Light and warmth sliders, plus a slow warm pulse for winding down
After: Sudoku in the working strip and a clock in the working triangle.
All the game's settings fit in the same strip.
How it was done:
The reader is a second-generation Mofibo/Storytel Reader, an Android 6 device built to run one app. In normal use it doesn't appear on a PC at all. What made this possible is StorytelReaderMods by Niklas Therning. It documents a USB mode you reach by holding the orange button while plugging in, and a patched boot image that turns on ADB.
  1. Test first. Before installing anything, I checked whether the broken area could still redraw. It couldn't, which ended my tablet idea and gave me a smaller, better goal.
  2. Back up. I read 10 partitions from the reader, twice each, and compared the copies.
  3. Change as little as possible. I flashed only the boot partition, then read it back and compared it before restarting.
  4. Build for the hardware you have. A small Android app of about 33 KB draws only in the working strip.
  5. Map what's left. I suspected another patch of screen still worked. Painting the dead area black revealed a small triangle, and that's where the clock lives now. The battery level sits just above a broken row of pixels.
Fixed the battery % pill here:
The second working patch. This version of the battery pill crosses a broken row of pixels, so I moved it higher and made it smaller.
I worked with Claude Code Opus 5.5 on Ultracode as my engineering partner. It did the research, compared the firmware and wrote the app. I held the buttons, ran the flash and photographed the screen, because the reader's own screenshots came back black. My phone camera and my eyes became the debugging tool.
What didn't work Disappointed
The game still won't start by itself. The home-screen prompt has no "Always" option, root wasn't available, and my startup trigger never launched the app. After a restart I need a PC to reopen it. The frozen image also stays on the top of the screen, though a piece of dark card would hide it.
What I'd pass on:
  • Broken doesn't mean finished. Ask what still works, then design around that.
  • Run the cheapest test first. Mine cost nothing and changed the whole plan.
  • Back-up before you change anything.
  • Credit the people whose work you stand on, as we all love to inspire and get aknowledgement.
If you try this: flashing can leave a device dead, and others have reported stuck readers. The patch also adds root and unrestricted ADB, so anyone with USB access could control the reader. Read the project's guide first, and go ahead only with a device you can afford to lose, and as we know that there is nothing else that the device can be used for so might as well try it.
What's sitting in your drawer that only looks finished?
What I and Claude Code Opus 5.5 did:
The reader went from invisible on USB to running a custom app in about roughly 2 hours, but I lost track on time to be honest, and with nothing written to it until a verified backup existed.
Stage
What happened
Result
Find the reader
Windows showed no device in normal use. The reader's boot settings have USB set to none, which is the likely reason.
Not visible
Reach the USB mode
Holding the orange button while plugging in showed USB ID 2207:310C. When you kept holding the button, the connection ended after 13 seconds and the reader went into recovery.
Visible, but unstable
Test the screen
When you turned the reader on, only the bottom of the screen changed.
General tablet ruled out
Install the driver
WinUSB through Zadig kept the reader connected for as long as we needed.
Stable connection
Check the partitions
The reader's partition table matched the project's published one exactly.
Safe to continue
Back up
10 partitions, about 1.8 GB, were each read twice and compared. It took about 6.5 minutes with no failures.
Verified backup
Compare the firmware
The reader runs a March 2025 build and the patched image comes from February 2023. The startup files differed only where expected, but the kernel also differed.
Risk accepted
Flash
Only the boot partition was written, then read back and compared before restarting.
Worked first time
Connect over ADB
ADB appeared as 2207:0011 with no extra driver and stayed connected.
Working
Build the app
A Sudoku app built without Gradle, using javac, d8, aapt2, zipalign and apksigner.
Displays and responds to touch
Add light controls
The app writes directly to the reader's white and warm light channels. Levels read back correctly over ADB.
Sliders work; pulse levels confirmed
Map the screen
Drawing the dead area black with a numbered grid revealed a working triangle and a thin band above the board.
Second usable area found
Use the triangle
Added a framed clock and a battery pill, which moved above a broken pixel row after your close-up photo.
Finished look
Where it went wrong!
• Auto-start failed. The home-screen prompt offers only "Just once" and appears in the dead area. pm disable-user had no effect, adb root gave no root, and su was denied. A boot receiver didn't launch the app either, and the logs don't explain why.
• Screenshots were useless. screencap returned an all-black image, so my photos were the only way to check the screen for Claude, costing extra on tokens.
• Some of my guesses were wrong. I first suspected the cable, then that USB was blocking screen updates. Neither looks right now.
• Research cost too much. One multi-agent research run used about 658,000 tokens and took about 27 minutes, after Claude said that it will take only a few minutes. My free screen test then decided more than that research Claude did, but that is just how it goes.
What is still missing? Thinking
The biggest gap is auto-start: after a restart, the game needs a PC to reopen it. Everything else below is either unconfirmed or a known limit.
Item
Status
Detail
Auto-start
Not working
An accessibility service might solve it, but it's untested, and turning it on needs a security setting you would change yourself.
Difficulty levels
Not confirmed
Built, but not yet tried on the reader. They set how many squares are removed, so they only roughly reflect difficulty.
Warm pulse
Partly confirmed
Light levels rise and fall over about 10 seconds. How it looks on the screen hasn't been checked.
Side buttons
Not confirmed
The app expects them to move the selected square, but they haven't been tried.
Standby and wake
Not tested
The clock's behaviour after standby is also unknown.
Scoring
Not confirmed
+10 for a correct number, -5 for a wrong one, -10 for a hint, plus a finishing bonus of 50, 100 or 200. The score has only been seen at 0.
Clock accuracy
Unknown
The reader's time was correct during the work, but it stays off Wi-Fi and may drift.
System updates
Risk remains
The update service is still on the reader and could overwrite the patched boot on Wi-Fi, so keep it offline.
Upper screen
Permanent limit
That area doesn't redraw, so software can't change it. Only a cover or a replacement panel could help, and I couldn't confirm a compatible panel.
Backup coverage
Partial
uboot, misc and backup read as all zeros, so there's no bootloader copy. Personal data and the cache weren't backed up.
Technical reference
These are the details people are most likely to ask about. Screen positions are specific to this reader's damage and were measured from photos, so treat them as approximate.
Device
Item
Value
Model
Mofibo/Storytel Reader, second generation (reports itself as "Reader 2")
Chip
Rockchip RK3128, according to the project
Memory
1 GB RAM and 8 GB storage, according to the project
System
Android 6.0.1, build dated 5 March 2025
Display
758 × 1024 e-ink
Touch
fts_ts controller, working in the bottom strip
Front light
White and warm channels, each 0-255, in /sys/class/backlight/
USB IDs
2207:310C in orange-button mode, 2207:0011 with ADB after the patch
Working screen areas
Area
Position in pixels
Used for
Bottom strip
y from 720 to 1024
Board, number pad and menu
Thin band
y from about 709 to 720
Black divider above the board
Triangle
x from about 488 to 758, y from about 415 to 514
Clock and battery level
Broken row
y of about 459, across the triangle
Avoided by the battery pill
Tools
Tool
Purpose
Source
rkflashtool 6.2
Reading and writing partitions
StorytelReaderMods, unsigned, no published checksum
boot-gen2-patched.img
Patched boot image that turns on ADB
StorytelReaderMods release, no published checksum
Zadig 2.9
WinUSB driver for the orange-button mode
Official site, valid signature
Android SDK
ADB, d8, aapt2, zipalign and apksigner
Already installed
Temurin JDK 17.0.21
Compiling the app
Adoptium, checksum matched
Claude Code with Claude Opus 5.5
Research, checks, scripts, firmware comparison, the app and this write-up
Anthropic, in the Claude desktop app; model ID claude-opus-5.5
Claude research agents
One multi-agent research and fact-check run, about 658,000 tokens
Same model as the main session
Run rkflashtool from Command Prompt, because PowerShell can silently corrupt binary output!
  • me_Cris
    me_Cris 3 days ago
    I haven't used anything like this, so I don't know much about it; however, the area where the clock and battery status are displayed puzzles me—isn't it affected very bad, or did you manage to hide the artifact lines?
    Anyway, it is nice.ClapClapClap
  • 91Raindrops
    91Raindrops 3 days ago in reply to me_Cris
    I tried with hiding the lines, and I was very close to open it up and see if the screen can be adjusted just a little bit, but I decided to "paint" the screen black to see the responsive parts. Then I added the ruler on the screen to bed able to see exact positions that I can use, as I used to be the Carpenter so that mindset still follows. And then instead of hiding the broken lines, I worked around them. Even though I still need to work on it, hopefully tomorrow or Monday, but for now I can play sudoku, see the time, adjust the settings and see when I need to charge it.
  • 91Raindrops
  • me_Cris
    me_Cris 2 days ago in reply to 91Raindrops
    You decide how much effort is needed.
