Member and Staff Blogs The calendar running on M5Stack Core Ink
  • Author Author: kk99
  • Date Created: 29 Dec 2021 8:55 AM Date Created
  • Views 6854 views
  • Likes 14 likes
  • esp32
  • m5stack
  • c
  • e-ink
  • display
  • c++
kk99
kk99
29 Dec 2021
M5Stack CoreInk
Some time ago I bought the M5Stack CoreInk board. This board has a nice e-ink display, ESP32 SoC, built-in battery and easy access to GPIOs. My initial purpose was to use it in some experiments or when needed make a quick solution to test other projects. In the meantime I decided to use this board to display a calendar. I have found nice inspiration here: ePaper Calendar
I decided to make the project more simpler version. In my project I have used the M5GFX library, Arduino IDE and RTC present on board. Below there is diagram with program flow:
diagram
After board initialization, the current date is obtained from RTC then the calendar drawing process is started. Next step is obtaining the current battery voltage and converting it to a percentage value. Then the final value is presented on the screen. Last stage is scheduling board wake-up after one hour and shutdown of it. The RTC was programmed to correct date with other sketch. I plan to add an option to manually set it via buttons in case something wrong happens with the built-in battery.
Below there is source code:
#include "M5CoreInk.h"
#include <M5GFX.h>
#include "esp_adc_cal.h"
#include "batteryIcon.h"
M5GFX display;
RTC_DateTypeDef RTCDate;
float getBatteryVoltage()
  analogSetPinAttenuation(35, ADC_11db);
  esp_adc_cal_characteristics_t *adc_chars = (esp_adc_cal_characteristics_t *) calloc(1, sizeof(esp_adc_cal_characteristics_t));
  esp_adc_cal_characterize(ADC_UNIT_1, ADC_ATTEN_DB_11, ADC_WIDTH_BIT_12, 3600, adc_chars);
  uint16_t adcValue = analogRead(35);
  return float(esp_adc_cal_raw_to_voltage(adcValue, adc_chars)) * 25.1 / 5.1 / 1000;
void drawBatteryStatus() {
  float batteryVoltage = getBatteryVoltage();
  int batteryPercentage = (batteryVoltage < 3.2) ? 0 : (batteryVoltage - 3.2) * 100;
  char batteryBuff[16] = { 0 };
  sprintf(batteryBuff, "%d%%", batteryPercentage);
  String strBattery = String(batteryBuff);
  display.setTextColor(TFT_BLACK);
  display.setFont(&fonts::FreeSans9pt7b);
  int32_t w;
  w = display.textWidth((char *)strBattery.c_str());
  display.drawPng(batteryIconPng, ~0u, (display.width() - w- 16), 4);
  display.setCursor((display.width() - w), 4);
  display.print(strBattery);
bool isLeapYear(int year) {
  if (((year % 4 == 0) && (year % 100 != 0)) || (year % 400 == 0)) {
    return true;
  return false;
int getDaysInMonth(int month, int year) {
  int daysInMonth[12] = {31, 28, 31, 30, 31, 30, 31, 31, 30, 31, 30, 31};
  if (month != 2) {
    return daysInMonth[(month - 1) % 12];
  if (isLeapYear(year)) {
    return 29;
  return 28;
int getDayOfWeek(int year, int month, int day)  /* 1 <= m <= 12,  y > 1752 (in the U.K.) */
  static int t[] = {0, 3, 2, 5, 0, 3, 5, 1, 4, 6, 2, 4};
  if ( month < 3 )
    year -= 1;
  return (year + year / 4 - year / 100 + year / 400 + t[month - 1] + day) % 7;
void drawCalendar(int year, int month, int day)
  const char *dows[7] = {"Sunday","Monday","Tuesday","Wednesday","Thursday","Friday","Saturday"};
  const char *months[12] = {"January","February","March","April","May","June","July","August","September","October","November","December"};
  int weekDay = getDayOfWeek(year, month, day);
  String strYear = String(year);
  display.setCursor(8,4);
  display.print(strYear);
  String strMonth = months[month-1];
  int daysInMonth = getDaysInMonth(month, year);
  display.setFont(&fonts::FreeSansBold9pt7b);
  int32_t w, h;
  w = display.textWidth((char *)strMonth.c_str());
  display.setCursor((display.width() - w)/2,4);
  display.print(strMonth);
  int curDay = day - weekDay;
  while(curDay > 1) {
    curDay -= 7;
  int x = 0;
  int y = 35;
  for(int i = 0 ; i < 7; i++)
    x = 4 + i * (display.width()-8)/7;
    w = display.textWidth(String(dows[i]).substring(0,2));
    display.setCursor(x + (display.width()/7-w)/2, y-8);
    display.print(String(dows[i]).substring(0,2));
  display.drawLine(0,44,display.width(),44,TFT_BLACK);
  y = 45;
  while(curDay <= daysInMonth)
    for(int i = 0; i < 7; i++)
      if(curDay >= 1 && curDay <= daysInMonth)
          display.setCursor(x,y);
          int32_t w, h;
          String strDay = String(curDay);
          if(curDay == day)
          w = display.textWidth(strDay.c_str());
          h = display.fontHeight();
          display.setCursor(x+(display.width()-8)/7/2-w/2,y+h/2);
          display.print(curDay);
      curDay++;
    y += 24;
void shutdown(int seconds)
    M5.rtc.clearIRQ();
    M5.rtc.SetAlarmIRQ(seconds);
    delay(10);
    digitalWrite(POWER_HOLD_PIN, LOW);
void setup() {
  M5.begin(false, false, false);
  digitalWrite(LED_EXT_PIN,HIGH);
  display.init();
  display.clear(TFT_WHITE);
  M5.rtc.GetDate(&RTCDate);
  drawCalendar(RTCDate.Year, RTCDate.Month, RTCDate.Date);
  drawBatteryStatus();
  display.display();
  display.waitDisplay();
  display.wakeup();
  shutdown(3600);
void loop() {
// batteryIcon.h
const uint8_t batteryIconPng[] = {
0x89, 0x50, 0x4E, 0x47, 0x0D, 0x0A, 0x1A, 0x0A, 0x00, 0x00, 0x00, 0x0D, 0x49, 0x48, 0x44, 0x52,
0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x10, 0x08, 0x00, 0x00, 0x00, 0x00, 0x3A, 0x98, 0xA0,
0xBD, 0x00, 0x00, 0x03, 0x8E, 0x7A, 0x54, 0x58, 0x74, 0x52, 0x61, 0x77, 0x20, 0x70, 0x72, 0x6F,
0x66, 0x69, 0x6C, 0x65, 0x20, 0x74, 0x79, 0x70, 0x65, 0x20, 0x65, 0x78, 0x69, 0x66, 0x00, 0x00,
0x78, 0xDA, 0xED, 0x56, 0x51, 0x92, 0xE3, 0x28, 0x0C, 0xFD, 0xE7, 0x14, 0x7B, 0x04, 0x24, 0x21,
0x04, 0xC7, 0xC1, 0x60, 0xAA, 0xF6, 0x06, 0x73, 0xFC, 0x7D, 0x60, 0x3B, 0x9D, 0xA4, 0xE3, 0x8D,
0xBB, 0xA7, 0xA7, 0x6A, 0x3F, 0xD6, 0xC4, 0x20, 0x0B, 0xF9, 0x49, 0xE8, 0x09, 0x62, 0xB7, 0xFE,
0xFA, 0xBB, 0xBB, 0xBF, 0x70, 0x31, 0x91, 0x77, 0x41, 0x2D, 0xC5, 0x1C, 0xA3, 0xC7, 0x15, 0x72,
0xC8, 0x5C, 0x20, 0x24, 0xBF, 0x5D, 0x65, 0xF6, 0xE4, 0xC3, 0xEC, 0xF7, 0x07, 0x7F, 0x08, 0x0F,
0x7A, 0x77, 0x9B, 0x60, 0xA8, 0x04, 0xA3, 0x6C, 0x8F, 0x29, 0xEE, 0xF6, 0x87, 0x9E, 0xFC, 0x03,
0x12, 0x15, 0x48, 0x7A, 0x07, 0x94, 0xEA, 0x3E, 0xB1, 0x3C, 0x4E, 0xE4, 0xB0, 0xE3, 0xA7, 0x27,
0xA0, 0xDD, 0x91, 0x8C, 0x88, 0x18, 0x42, 0xDB, 0x81, 0xF2, 0x0E, 0x24, 0xBC, 0x4D, 0xD0, 0x0E,
0x50, 0xB6, 0x65, 0xF9, 0x98, 0x93, 0xDD, 0x2F, 0x61, 0x59, 0xB7, 0xB1, 0x1D, 0x2B, 0x49, 0xDB,
0xED, 0x46, 0xD7, 0x77, 0x30, 0xBF, 0x6C, 0xC3, 0xF3, 0x73, 0x30, 0x64, 0xAF, 0x29, 0xFC, 0x08,
0xF3, 0x2A, 0x24, 0x1E, 0x3D, 0x0B, 0x6F, 0x01, 0xC8, 0xB8, 0xD9, 0x49, 0x81, 0x40, 0x5B, 0xCF,
0x43, 0x8A, 0x90, 0xC3, 0xEC, 0x59, 0xF2, 0x1E, 0x09, 0x12, 0xF2, 0x2A, 0x4F, 0xFE, 0x2E, 0x2A,
0xF7, 0xCC, 0xCA, 0x4D, 0xA2, 0x13, 0xFD, 0x13, 0x29, 0x12, 0x37, 0xBD, 0x83, 0xE2, 0x31, 0x99,
0xF1, 0x36, 0xBE, 0xD4, 0x93, 0xBE, 0x4E, 0xBE, 0x9B, 0x29, 0xBE, 0xF3, 0x2C, 0xF5, 0xE6, 0xF9,
0x41, 0x8F, 0xBC, 0xC5, 0xE7, 0xE5, 0x1C, 0x77, 0xEF, 0x2D, 0xB9, 0xDE, 0xD7, 0x6D, 0x75, 0x25,
0x44, 0xA4, 0x34, 0xEE, 0x8B, 0x3A, 0x96, 0x32, 0x25, 0x18, 0x22, 0xED, 0x41, 0xE6, 0x6B, 0x11,
0xCD, 0x70, 0x2B, 0x64, 0x9B, 0x2D, 0xA3, 0x25, 0x87, 0xEA, 0xAD, 0xA0, 0xBC, 0xF9, 0x0A, 0x8E,
0x16, 0xC8, 0x99, 0x18, 0xB4, 0x74, 0x0A, 0xD4, 0xA8, 0x50, 0xA7, 0x75, 0x8E, 0x95, 0x2A, 0x42,
0x0C, 0xBC, 0xB2, 0x61, 0x64, 0xAE, 0x2C, 0x53, 0x97, 0xC4, 0x38, 0x73, 0x15, 0xEF, 0xC0, 0x53,
0x18, 0x8D, 0x3A, 0x9B, 0x64, 0x69, 0x92, 0xC0, 0x56, 0x05, 0xBD, 0x02, 0x2D, 0xDF, 0x62, 0xA1,
0xE9, 0x37, 0x4F, 0x77, 0x95, 0x12, 0x1C, 0x37, 0x82, 0x25, 0x76, 0x59, 0x85, 0xDF, 0x49, 0x3F,
0xFF, 0x4C, 0x3B, 0x05, 0xEA, 0xB3, 0x2A, 0xB1, 0xAD, 0xD3, 0x2D, 0x57, 0x88, 0x8B, 0x47, 0x11,
0x8E, 0xCD, 0x0E, 0xE6, 0x46, 0x0F, 0x2B, 0x10, 0x42, 0xFD, 0xA8, 0x23, 0x9D, 0x09, 0x3E, 0xDA,
0xF3, 0x35, 0x78, 0x15, 0x30, 0xA8, 0x33, 0xCD, 0x09, 0x0B, 0x2C, 0x7E, 0xD9, 0x20, 0x16, 0xA5,
0xBD, 0xB6, 0x46, 0x1D, 0xC9, 0x24, 0x5A, 0x60, 0xA8, 0x18, 0xB7, 0xBD, 0x46, 0xD6, 0x76, 0x00,
0xA4, 0x08, 0xBE, 0x15, 0xC1, 0x90, 0x80, 0x01, 0x1F, 0x49, 0x94, 0x22, 0x79, 0x63, 0x36, 0x22,
0xE4, 0x31, 0x81, 0x9F, 0x02, 0xA0, 0xC4, 0x12, 0x78, 0x01, 0x05, 0xA4, 0xCA, 0x0D, 0x51, 0x72,
0x10, 0x89, 0x20, 0x27, 0xF1, 0xF0, 0x8D, 0x77, 0x8C, 0xA6, 0x2D, 0x2B, 0x6F, 0x6A, 0x9C, 0x59,
0x20, 0x42, 0xB1, 0x8D, 0x0C, 0xD4, 0x64, 0x29, 0xE0, 0x2A, 0xE0, 0x60, 0x43, 0xFD, 0x58, 0x48,
0xA8, 0xA1, 0xA2, 0xA2, 0x41, 0x55, 0xA3, 0x9A, 0x26, 0xCD, 0x5A, 0xA2, 0xC4, 0x10, 0x35, 0xC6,
0x68, 0x71, 0x1C, 0x7E, 0xC5, 0xC4, 0x82, 0xA9, 0x45, 0x33, 0x4B, 0x96, 0xAD, 0x24, 0x49, 0x21,
0x69, 0x8A, 0xC9, 0x52, 0x72, 0x29, 0xA7, 0x92, 0x39, 0x0B, 0x0E, 0x47, 0xCD, 0x31, 0x5B, 0x4E,
0x39, 0xE7, 0x52, 0xE0, 0xB4, 0x00, 0xB9, 0xE0, 0xED, 0x02, 0x83, 0x52, 0x16, 0x5E, 0x64, 0x09,
0x8B, 0x2E, 0x71, 0xB1, 0x25, 0x2D, 0x79, 0x29, 0x15, 0xE5, 0x53, 0x43, 0xD5, 0x1A, 0xAB, 0xD5,
0xE4, 0x6A, 0xAE, 0xA5, 0x71, 0x93, 0x86, 0x73, 0xA2, 0xC5, 0x66, 0x2D, 0xB5, 0xDC, 0xCA, 0x4A,
0x2B, 0x4A, 0x69, 0x0D, 0xAB, 0xAE, 0x71, 0xB5, 0x35, 0xAD, 0x79, 0x2D, 0x1D, 0xA5, 0xD6, 0xA5,
0x87, 0xAE, 0x3D, 0x76, 0xEB, 0xA9, 0xE7, 0x5E, 0x6E, 0xAC, 0x91, 0xDB, 0x68, 0xFD, 0xD4, 0xAE,
0xB3, 0x46, 0x07, 0x6B, 0x3C, 0x99, 0x1A, 0x86, 0x76, 0x63, 0x0D, 0xAF, 0x9A, 0x1D, 0x10, 0x34,
0x8E, 0x13, 0x1D, 0x9C, 0x81, 0x31, 0x0E, 0x04, 0xC6, 0x6D, 0x30, 0x80, 0x82, 0xE6, 0xC1, 0x99,
0x4F, 0x14, 0x02, 0xBB, 0x41, 0xDD, 0xE0, 0xCC, 0x67, 0xC6, 0xAE, 0x50, 0x46, 0x94, 0x3A, 0xC8,
0x69, 0x34, 0x18, 0x03, 0x83, 0x61, 0x25, 0xD6, 0x4E, 0x37, 0xEE, 0x3E, 0x98, 0x7B, 0xE0, 0xCD,
0x85, 0xF0, 0x5B, 0xBC, 0xF1, 0xC1, 0x9C, 0x1B, 0xD4, 0xFD, 0x04, 0x73, 0x6E, 0x50, 0x77, 0xC2,
0xDC, 0x67, 0xDE, 0x5E, 0xB0, 0xD6, 0xC6, 0xBF, 0x4D, 0xF5, 0xE2, 0x26, 0x43, 0x63, 0x1B, 0x8E,
0xA4, 0x7A, 0xC1, 0xF6, 0x83, 0x51, 0xE1, 0x84, 0x1F, 0xFE, 0x93, 0xAE, 0x8D, 0x82, 0xB3, 0xD1,
0xBD, 0xB5, 0xE9, 0xD7, 0x60, 0xDD, 0xD7, 0xFC, 0x9E, 0x9B, 0xB8, 0x8B, 0x18, 0x6F, 0xE3, 0x72,
0xDF, 0xF3, 0xFF, 0x79, 0x74, 0x3F, 0x13, 0x8F, 0x1F, 0x40, 0x6F, 0xE2, 0xB8, 0x98, 0x6E, 0xF7,
0x33, 0x30, 0x0F, 0xAC, 0x5D, 0x83, 0x81, 0x15, 0x7D, 0xCC, 0xAE, 0xFF, 0x89, 0xA5, 0xDD, 0x59,
0xDD, 0xCD, 0xBA, 0x0B, 0xB4, 0xFF, 0x39, 0xD6, 0x5E, 0xC5, 0xE4, 0x2E, 0x95, 0xE2, 0x77, 0x2A,
0xFB, 0xDF, 0x61, 0x30, 0x2B, 0xBB, 0x48, 0x39, 0x28, 0x05, 0x1D, 0x9F, 0xAF, 0x63, 0x74, 0x87,
0xE0, 0xBD, 0xB5, 0x8E, 0x43, 0xE4, 0x78, 0xA8, 0x37, 0xFD, 0xCB, 0xF9, 0xE7, 0x49, 0x72, 0x27,
0x13, 0xEF, 0x80, 0x3E, 0xCD, 0x3B, 0xFF, 0xC5, 0x17, 0xCE, 0x22, 0x3B, 0x8B, 0xE8, 0xCB, 0x91,
0xB9, 0xF3, 0x08, 0x5E, 0x7A, 0x3E, 0x05, 0x7E, 0x17, 0x11, 0xFD, 0x2E, 0xD0, 0x97, 0x23, 0x73,
0xEF, 0x68, 0xBD, 0x1A, 0xD9, 0x3B, 0xA0, 0xCB, 0x91, 0xB9, 0xAB, 0x05, 0xF7, 0xCE, 0xD1, 0x55,
0xA0, 0xB7, 0x91, 0xB9, 0xAF, 0x6E, 0x85, 0x33, 0x47, 0xFF, 0x03, 0x5D, 0x02, 0x92, 0x5D, 0x66,
0x9D, 0x5A, 0xEF, 0xBF, 0x35, 0xBA, 0xF1, 0x69, 0xFA, 0x11, 0x4A, 0x3B, 0x73, 0xD8, 0xF1, 0x49,
0x95, 0xDD, 0x3F, 0xED, 0x77, 0xC3, 0xED, 0xBF, 0xC0, 0xB7, 0x3B, 0x00, 0x00, 0x0F, 0x8B, 0x69,
0x54, 0x58, 0x74, 0x58, 0x4D, 0x4C, 0x3A, 0x63, 0x6F, 0x6D, 0x2E, 0x61, 0x64, 0x6F, 0x62, 0x65,
0x2E, 0x78, 0x6D, 0x70, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3C, 0x3F, 0x78, 0x70, 0x61, 0x63, 0x6B,
0x65, 0x74, 0x20, 0x62, 0x65, 0x67, 0x69, 0x6E, 0x3D, 0x22, 0xEF, 0xBB, 0xBF, 0x22, 0x20, 0x69,
0x64, 0x3D, 0x22, 0x57, 0x35, 0x4D, 0x30, 0x4D, 0x70, 0x43, 0x65, 0x68, 0x69, 0x48, 0x7A, 0x72,
0x65, 0x53, 0x7A, 0x4E, 0x54, 0x63, 0x7A, 0x6B, 0x63, 0x39, 0x64, 0x22, 0x3F, 0x3E, 0x0A, 0x3C,
0x78, 0x3A, 0x78, 0x6D, 0x70, 0x6D, 0x65, 0x74, 0x61, 0x20, 0x78, 0x6D, 0x6C, 0x6E, 0x73, 0x3A,
0x78, 0x3D, 0x22, 0x61, 0x64, 0x6F, 0x62, 0x65, 0x3A, 0x6E, 0x73, 0x3A, 0x6D, 0x65, 0x74, 0x61,
0x2F, 0x22, 0x20, 0x78, 0x3A, 0x78, 0x6D, 0x70, 0x74, 0x6B, 0x3D, 0x22, 0x58, 0x4D, 0x50, 0x20,
0x43, 0x6F, 0x72, 0x65, 0x20, 0x34, 0x2E, 0x34, 0x2E, 0x30, 0x2D, 0x45, 0x78, 0x69, 0x76, 0x32,
0x22, 0x3E, 0x0A, 0x20, 0x3C, 0x72, 0x64, 0x66, 0x3A, 0x52, 0x44, 0x46, 0x20, 0x78, 0x6D, 0x6C,
0x6E, 0x73, 0x3A, 0x72, 0x64, 0x66, 0x3D, 0x22, 0x68, 0x74, 0x74, 0x70, 0x3A, 0x2F, 0x2F, 0x77,
0x77, 0x77, 0x2E, 0x77, 0x33, 0x2E, 0x6F, 0x72, 0x67, 0x2F, 0x31, 0x39, 0x39, 0x39, 0x2F, 0x30,
0x32, 0x2F, 0x32, 0x32, 0x2D, 0x72, 0x64, 0x66, 0x2D, 0x73, 0x79, 0x6E, 0x74, 0x61, 0x78, 0x2D,
0x6E, 0x73, 0x23, 0x22, 0x3E, 0x0A, 0x20, 0x20, 0x3C, 0x72, 0x64, 0x66, 0x3A, 0x44, 0x65, 0x73,
0x63, 0x72, 0x69, 0x70, 0x74, 0x69, 0x6F, 0x6E, 0x20, 0x72, 0x64, 0x66, 0x3A, 0x61, 0x62, 0x6F,
0x75, 0x74, 0x3D, 0x22, 0x22, 0x0A, 0x20, 0x20, 0x20, 0x20, 0x78, 0x6D, 0x6C, 0x6E, 0x73, 0x3A,
0x69, 0x70, 0x74, 0x63, 0x45, 0x78, 0x74, 0x3D, 0x22, 0x68, 0x74, 0x74, 0x70, 0x3A, 0x2F, 0x2F,
0x69, 0x70, 0x74, 0x63, 0x2E, 0x6F, 0x72, 0x67, 0x2F, 0x73, 0x74, 0x64, 0x2F, 0x49, 0x70, 0x74,
0x63, 0x34, 0x78, 0x6D, 0x70, 0x45, 0x78, 0x74, 0x2F, 0x32, 0x30, 0x30, 0x38, 0x2D, 0x30, 0x32,
0x2D, 0x32, 0x39, 0x2F, 0x22, 0x0A, 0x20, 0x20, 0x20, 0x20, 0x78, 0x6D, 0x6C, 0x6E, 0x73, 0x3A,
0x78, 0x6D, 0x70, 0x4D, 0x4D, 0x3D, 0x22, 0x68, 0x74, 0x74, 0x70, 0x3A, 0x2F, 0x2F, 0x6E, 0x73,
0x2E, 0x61, 0x64, 0x6F, 0x62, 0x65, 0x2E, 0x63, 0x6F, 0x6D, 0x2F, 0x78, 0x61, 0x70, 0x2F, 0x31,
0x2E, 0x30, 0x2F, 0x6D, 0x6D, 0x2F, 0x22, 0x0A, 0x20, 0x20, 0x20, 0x20, 0x78, 0x6D, 0x6C, 0x6E,
0x73, 0x3A, 0x73, 0x74, 0x45, 0x76, 0x74, 0x3D, 0x22, 0x68, 0x74, 0x74, 0x70, 0x3A, 0x2F, 0x2F,
0x6E, 0x73, 0x2E, 0x61, 0x64, 0x6F, 0x62, 0x65, 0x2E, 0x63, 0x6F, 0x6D, 0x2F, 0x78, 0x61, 0x70,
0x2F, 0x31, 0x2E, 0x30, 0x2F, 0x73, 0x54, 0x79, 0x70, 0x65, 0x2F, 0x52, 0x65, 0x73, 0x6F, 0x75,
0x72, 0x63, 0x65, 0x45, 0x76, 0x65, 0x6E, 0x74, 0x23, 0x22, 0x0A, 0x20, 0x20, 0x20, 0x20, 0x78,
0x6D, 0x6C, 0x6E, 0x73, 0x3A, 0x70, 0x6C, 0x75, 0x73, 0x3D, 0x22, 0x68, 0x74, 0x74, 0x70, 0x3A,
0x2F, 0x2F, 0x6E, 0x73, 0x2E, 0x75, 0x73, 0x65, 0x70, 0x6C, 0x75, 0x73, 0x2E, 0x6F, 0x72, 0x67,
0x2F, 0x6C, 0x64, 0x66, 0x2F, 0x78, 0x6D, 0x70, 0x2F, 0x31, 0x2E, 0x30, 0x2F, 0x22, 0x0A, 0x20,
0x20, 0x20, 0x20, 0x78, 0x6D, 0x6C, 0x6E, 0x73, 0x3A, 0x47, 0x49, 0x4D, 0x50, 0x3D, 0x22, 0x68,
0x74, 0x74, 0x70, 0x3A, 0x2F, 0x2F, 0x77, 0x77, 0x77, 0x2E, 0x67, 0x69, 0x6D, 0x70, 0x2E, 0x6F,
0x72, 0x67, 0x2F, 0x78, 0x6D, 0x70, 0x2F, 0x22, 0x0A, 0x20, 0x20, 0x20, 0x20, 0x78, 0x6D, 0x6C,
0x6E, 0x73, 0x3A, 0x64, 0x63, 0x3D, 0x22, 0x68, 0x74, 0x74, 0x70, 0x3A, 0x2F, 0x2F, 0x70, 0x75,
0x72, 0x6C, 0x2E, 0x6F, 0x72, 0x67, 0x2F, 0x64, 0x63, 0x2F, 0x65, 0x6C, 0x65, 0x6D, 0x65, 0x6E,
0x74, 0x73, 0x2F, 0x31, 0x2E, 0x31, 0x2F, 0x22, 0x0A, 0x20, 0x20, 0x20, 0x20, 0x78, 0x6D, 0x6C,
0x6E, 0x73, 0x3A, 0x74, 0x69, 0x66, 0x66, 0x3D, 0x22, 0x68, 0x74, 0x74, 0x70, 0x3A, 0x2F, 0x2F,
0x6E, 0x73, 0x2E, 0x61, 0x64, 0x6F, 0x62, 0x65, 0x2E, 0x63, 0x6F, 0x6D, 0x2F, 0x74, 0x69, 0x66,
0x66, 0x2F, 0x31, 0x2E, 0x30, 0x2F, 0x22, 0x0A, 0x20, 0x20, 0x20, 0x20, 0x78, 0x6D, 0x6C, 0x6E,
0x73, 0x3A, 0x78, 0x6D, 0x70, 0x3D, 0x22, 0x68, 0x74, 0x74, 0x70, 0x3A, 0x2F, 0x2F, 0x6E, 0x73,
0x2E, 0x30, 0x2F, 0x22, 0x0A, 0x20, 0x20, 0x20, 0x78, 0x6D, 0x70, 0x4D, 0x4D, 0x3A, 0x44, 0x6F,
0x63, 0x75, 0x6D, 0x65, 0x6E, 0x74, 0x49, 0x44, 0x3D, 0x22, 0x67, 0x69, 0x6D, 0x70, 0x3A, 0x64,
0x6F, 0x63, 0x69, 0x64, 0x3A, 0x67, 0x69, 0x6D, 0x70, 0x3A, 0x66, 0x38, 0x34, 0x33, 0x61, 0x62,
0x34, 0x37, 0x2D, 0x31, 0x35, 0x34, 0x30, 0x2D, 0x34, 0x66, 0x38, 0x61, 0x2D, 0x38, 0x36, 0x37,
0x36, 0x2D, 0x65, 0x66, 0x66, 0x39, 0x38, 0x38, 0x61, 0x65, 0x31, 0x66, 0x32, 0x62, 0x22, 0x0A,
0x20, 0x20, 0x20, 0x78, 0x6D, 0x70, 0x4D, 0x4D, 0x3A, 0x49, 0x6E, 0x73, 0x74, 0x61, 0x6E, 0x63,
0x65, 0x49, 0x44, 0x3D, 0x22, 0x78, 0x6D, 0x70, 0x2E, 0x69, 0x69, 0x64, 0x3A, 0x64, 0x64, 0x66,
0x65, 0x66, 0x30, 0x66, 0x32, 0x2D, 0x34, 0x35, 0x64, 0x33, 0x2D, 0x34, 0x39, 0x38, 0x32, 0x2D,
0x61, 0x30, 0x38, 0x31, 0x2D, 0x33, 0x36, 0x34, 0x30, 0x36, 0x37, 0x63, 0x64, 0x33, 0x61, 0x32,
0x64, 0x22, 0x0A, 0x20, 0x20, 0x20, 0x78, 0x6D, 0x70, 0x4D, 0x4D, 0x3A, 0x4F, 0x72, 0x69, 0x67,
0x69, 0x6E, 0x61, 0x6C, 0x44, 0x6F, 0x63, 0x75, 0x6D, 0x65, 0x6E, 0x74, 0x49, 0x44, 0x3D, 0x22,
0x78, 0x6D, 0x70, 0x2E, 0x64, 0x69, 0x64, 0x3A, 0x66, 0x35, 0x33, 0x63, 0x61, 0x37, 0x34, 0x34,
0x2D, 0x66, 0x37, 0x63, 0x64, 0x2D, 0x34, 0x65, 0x38, 0x38, 0x2D, 0x61, 0x33, 0x39, 0x61, 0x2D,
0x66, 0x39, 0x37, 0x39, 0x61, 0x34, 0x35, 0x32, 0x64, 0x64, 0x64, 0x61, 0x22, 0x0A, 0x20, 0x20,
0x20, 0x47, 0x49, 0x4D, 0x50, 0x3A, 0x41, 0x50, 0x49, 0x3D, 0x22, 0x32, 0x2E, 0x30, 0x22, 0x0A,
0x20, 0x20, 0x20, 0x47, 0x49, 0x4D, 0x50, 0x3A, 0x50, 0x6C, 0x61, 0x74, 0x66, 0x6F, 0x72, 0x6D,
0x3D, 0x22, 0x4C, 0x69, 0x6E, 0x75, 0x78, 0x22, 0x0A, 0x20, 0x20, 0x20, 0x47, 0x49, 0x4D, 0x50,
0x3A, 0x54, 0x69, 0x6D, 0x65, 0x53, 0x74, 0x61, 0x6D, 0x70, 0x3D, 0x22, 0x31, 0x36, 0x34, 0x31,
0x30, 0x35, 0x32, 0x30, 0x30, 0x32, 0x33, 0x30, 0x34, 0x34, 0x35, 0x36, 0x22, 0x0A, 0x20, 0x20,
0x20, 0x47, 0x49, 0x4D, 0x50, 0x3A, 0x56, 0x65, 0x72, 0x73, 0x69, 0x6F, 0x6E, 0x3D, 0x22, 0x32,
0x2E, 0x31, 0x30, 0x2E, 0x32, 0x32, 0x22, 0x0A, 0x20, 0x20, 0x20, 0x64, 0x63, 0x3A, 0x46, 0x6F,
0x72, 0x6D, 0x61, 0x74, 0x3D, 0x22, 0x69, 0x6D, 0x61, 0x67, 0x65, 0x2F, 0x70, 0x6E, 0x67, 0x22,
0x0A, 0x20, 0x20, 0x20, 0x74, 0x69, 0x66, 0x66, 0x3A, 0x4F, 0x72, 0x69, 0x65, 0x6E, 0x74, 0x61,
0x74, 0x69, 0x6F, 0x6E, 0x3D, 0x22, 0x31, 0x22, 0x0A, 0x20, 0x20, 0x20, 0x78, 0x6D, 0x70, 0x3A,
0x43, 0x72, 0x65, 0x61, 0x74, 0x6F, 0x72, 0x54, 0x6F, 0x6F, 0x6C, 0x3D, 0x22, 0x47, 0x49, 0x4D,
0x50, 0x20, 0x32, 0x2E, 0x31, 0x30, 0x22, 0x3E, 0x0A, 0x20, 0x20, 0x20, 0x3C, 0x69, 0x70, 0x74,
0x63, 0x45, 0x78, 0x74, 0x3A, 0x4C, 0x6F, 0x63, 0x61, 0x74, 0x69, 0x6F, 0x6E, 0x43, 0x72, 0x65,
0x61, 0x74, 0x65, 0x64, 0x3E, 0x0A, 0x20, 0x20, 0x20, 0x20, 0x3C, 0x72, 0x64, 0x66, 0x3A, 0x42,
0x61, 0x67, 0x2F, 0x3E, 0x0A, 0x20, 0x20, 0x20, 0x3C, 0x2F, 0x69, 0x70, 0x74, 0x63, 0x45, 0x78,
0x74, 0x3A, 0x4C, 0x6F, 0x63, 0x61, 0x74, 0x69, 0x6F, 0x6E, 0x43, 0x72, 0x65, 0x61, 0x74, 0x65,
0x64, 0x3E, 0x0A, 0x20, 0x20, 0x20, 0x3C, 0x69, 0x70, 0x74, 0x63, 0x45, 0x78, 0x74, 0x3A, 0x4C,
0x6F, 0x63, 0x61, 0x74, 0x69, 0x6F, 0x6E, 0x53, 0x68, 0x6F, 0x77, 0x6E, 0x3E, 0x0A, 0x20, 0x20,
0x20, 0x20, 0x3C, 0x72, 0x64, 0x66, 0x3A, 0x42, 0x61, 0x67, 0x2F, 0x3E, 0x0A, 0x20, 0x20, 0x20,
0x3C, 0x2F, 0x69, 0x70, 0x74, 0x63, 0x45, 0x78, 0x74, 0x3A, 0x4C, 0x6F, 0x63, 0x61, 0x74, 0x69,
0x6F, 0x6E, 0x53, 0x68, 0x6F, 0x77, 0x6E, 0x3E, 0x0A, 0x20, 0x20, 0x20, 0x3C, 0x69, 0x70, 0x74,
0x63, 0x45, 0x78, 0x74, 0x3A, 0x41, 0x72, 0x74, 0x77, 0x6F, 0x72, 0x6B, 0x4F, 0x72, 0x4F, 0x62,
0x6A, 0x65, 0x63, 0x74, 0x3E, 0x0A, 0x20, 0x20, 0x20, 0x20, 0x3C, 0x72, 0x64, 0x66, 0x3A, 0x42,
0x74, 0x3A, 0x41, 0x72, 0x74, 0x77, 0x6F, 0x72, 0x6B, 0x4F, 0x72, 0x4F, 0x62, 0x6A, 0x65, 0x63,
0x74, 0x3E, 0x0A, 0x20, 0x20, 0x20, 0x3C, 0x69, 0x70, 0x74, 0x63, 0x45, 0x78, 0x74, 0x3A, 0x52,
0x65, 0x67, 0x69, 0x73, 0x74, 0x72, 0x79, 0x49, 0x64, 0x3E, 0x0A, 0x20, 0x20, 0x20, 0x20, 0x3C,
0x72, 0x64, 0x66, 0x3A, 0x42, 0x61, 0x67, 0x2F, 0x3E, 0x0A, 0x20, 0x20, 0x20, 0x3C, 0x2F, 0x69,
0x70, 0x74, 0x63, 0x45, 0x78, 0x74, 0x3A, 0x52, 0x65, 0x67, 0x69, 0x73, 0x74, 0x72, 0x79, 0x49,
0x64, 0x3E, 0x0A, 0x20, 0x20, 0x20, 0x3C, 0x78, 0x6D, 0x70, 0x4D, 0x4D, 0x3A, 0x48, 0x69, 0x73,
0x74, 0x6F, 0x72, 0x79, 0x3E, 0x0A, 0x20, 0x20, 0x20, 0x20, 0x3C, 0x72, 0x64, 0x66, 0x3A, 0x53,
0x65, 0x71, 0x3E, 0x0A, 0x20, 0x20, 0x20, 0x20, 0x20, 0x3C, 0x72, 0x64, 0x66, 0x3A, 0x6C, 0x69,
0x0A, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x73, 0x74, 0x45, 0x76, 0x74, 0x3A, 0x61, 0x63, 0x74,
0x69, 0x6F, 0x6E, 0x3D, 0x22, 0x73, 0x61, 0x76, 0x65, 0x64, 0x22, 0x0A, 0x20, 0x20, 0x20, 0x20,
0x20, 0x20, 0x73, 0x74, 0x45, 0x76, 0x74, 0x3A, 0x63, 0x68, 0x61, 0x6E, 0x67, 0x65, 0x64, 0x3D,
0x22, 0x2F, 0x22, 0x0A, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x73, 0x74, 0x45, 0x76, 0x74, 0x3A,
0x69, 0x6E, 0x73, 0x74, 0x61, 0x6E, 0x63, 0x65, 0x49, 0x44, 0x3D, 0x22, 0x78, 0x6D, 0x70, 0x2E,
0x69, 0x69, 0x64, 0x3A, 0x61, 0x62, 0x63, 0x63, 0x63, 0x37, 0x32, 0x66, 0x2D, 0x64, 0x38, 0x33,
0x31, 0x2D, 0x34, 0x38, 0x62, 0x39, 0x2D, 0x39, 0x65, 0x65, 0x61, 0x2D, 0x33, 0x61, 0x37, 0x61,
0x38, 0x31, 0x35, 0x39, 0x32, 0x38, 0x63, 0x65, 0x22, 0x0A, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20,
0x73, 0x74, 0x45, 0x76, 0x74, 0x3A, 0x73, 0x6F, 0x66, 0x74, 0x77, 0x61, 0x72, 0x65, 0x41, 0x67,
0x65, 0x6E, 0x74, 0x3D, 0x22, 0x47, 0x69, 0x6D, 0x70, 0x20, 0x32, 0x2E, 0x31, 0x30, 0x20, 0x28,
0x4C, 0x69, 0x6E, 0x75, 0x78, 0x29, 0x22, 0x0A, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x73, 0x74,
0x45, 0x76, 0x74, 0x3A, 0x77, 0x68, 0x65, 0x6E, 0x3D, 0x22, 0x2B, 0x30, 0x31, 0x3A, 0x30, 0x30,
0x22, 0x2F, 0x3E, 0x0A, 0x20, 0x20, 0x20, 0x20, 0x3C, 0x2F, 0x72, 0x64, 0x66, 0x3A, 0x53, 0x65,
0x71, 0x3E, 0x0A, 0x20, 0x20, 0x20, 0x3C, 0x2F, 0x78, 0x6D, 0x70, 0x4D, 0x4D, 0x3A, 0x48, 0x69,
0x73, 0x74, 0x6F, 0x72, 0x79, 0x3E, 0x0A, 0x20, 0x20, 0x20, 0x3C, 0x70, 0x6C, 0x75, 0x73, 0x3A,
0x49, 0x6D, 0x61, 0x67, 0x65, 0x53, 0x75, 0x70, 0x70, 0x6C, 0x69, 0x65, 0x72, 0x3E, 0x0A, 0x20,
0x20, 0x20, 0x20, 0x3C, 0x72, 0x64, 0x66, 0x3A, 0x53, 0x65, 0x71, 0x2F, 0x3E, 0x0A, 0x20, 0x20,
0x20, 0x3C, 0x2F, 0x70, 0x6C, 0x75, 0x73, 0x3A, 0x49, 0x6D, 0x61, 0x67, 0x65, 0x53, 0x75, 0x70,
0x70, 0x6C, 0x69, 0x65, 0x72, 0x3E, 0x0A, 0x20, 0x20, 0x20, 0x3C, 0x70, 0x6C, 0x75, 0x73, 0x3A,
0x49, 0x6D, 0x61, 0x67, 0x65, 0x43, 0x72, 0x65, 0x61, 0x74, 0x6F, 0x72, 0x3E, 0x0A, 0x20, 0x20,
0x20, 0x20, 0x3C, 0x72, 0x64, 0x66, 0x3A, 0x53, 0x65, 0x71, 0x2F, 0x3E, 0x0A, 0x20, 0x20, 0x20,
0x3C, 0x2F, 0x70, 0x6C, 0x75, 0x73, 0x3A, 0x49, 0x6D, 0x61, 0x67, 0x65, 0x43, 0x72, 0x65, 0x61,
0x74, 0x6F, 0x72, 0x3E, 0x0A, 0x20, 0x20, 0x20, 0x3C, 0x70, 0x6C, 0x75, 0x73, 0x3A, 0x43, 0x6F,
0x70, 0x79, 0x72, 0x69, 0x67, 0x68, 0x74, 0x4F, 0x77, 0x6E, 0x65, 0x72, 0x3E, 0x0A, 0x20, 0x20,
0x3C, 0x2F, 0x70, 0x6C, 0x75, 0x73, 0x3A, 0x43, 0x6F, 0x70, 0x79, 0x72, 0x69, 0x67, 0x68, 0x74,
0x4F, 0x77, 0x6E, 0x65, 0x72, 0x3E, 0x0A, 0x20, 0x20, 0x20, 0x3C, 0x70, 0x6C, 0x75, 0x73, 0x3A,
0x4C, 0x69, 0x63, 0x65, 0x6E, 0x73, 0x6F, 0x72, 0x3E, 0x0A, 0x20, 0x20, 0x20, 0x20, 0x3C, 0x72,
0x64, 0x66, 0x3A, 0x53, 0x65, 0x71, 0x2F, 0x3E, 0x0A, 0x20, 0x20, 0x20, 0x3C, 0x2F, 0x70, 0x6C,
0x75, 0x73, 0x3A, 0x4C, 0x69, 0x63, 0x65, 0x6E, 0x73, 0x6F, 0x72, 0x3E, 0x0A, 0x20, 0x20, 0x3C,
0x2F, 0x72, 0x64, 0x66, 0x3A, 0x44, 0x65, 0x73, 0x63, 0x72, 0x69, 0x70, 0x74, 0x69, 0x6F, 0x6E,
0x3E, 0x0A, 0x20, 0x3C, 0x2F, 0x72, 0x64, 0x66, 0x3A, 0x52, 0x44, 0x46, 0x3E, 0x0A, 0x3C, 0x2F,
0x78, 0x3A, 0x78, 0x6D, 0x70, 0x6D, 0x65, 0x74, 0x61, 0x3E, 0x0A, 0x20, 0x20, 0x20, 0x20, 0x20,
0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20,
0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x0A,
0x20, 0x20, 0x20, 0x20, 0x0A, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20,
0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x0A, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20,
0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x0A, 0x20,
0x20, 0x20, 0x20, 0x0A, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20,
0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x0A, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20,
0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x0A, 0x20, 0x20,
0x20, 0x20, 0x0A, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20,
0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x0A, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20,
0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x0A, 0x20, 0x20, 0x20,
0x20, 0x0A, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20,
0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x0A, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20,
0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x0A, 0x20, 0x20, 0x20, 0x20,
0x0A, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20,
0x20, 0x20, 0x20, 0x20, 0x20, 0x0A, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20,
0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x0A, 0x20, 0x20, 0x20, 0x20, 0x20,
0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x0A, 0x3C, 0x3F, 0x78, 0x70, 0x61,
0x63, 0x6B, 0x65, 0x74, 0x20, 0x65, 0x6E, 0x64, 0x3D, 0x22, 0x77, 0x22, 0x3F, 0x3E, 0xC4, 0x4F,
0x31, 0xAF, 0x00, 0x00, 0x00, 0x02, 0x62, 0x4B, 0x47, 0x44, 0x00, 0xFF, 0x87, 0x8F, 0xCC, 0xBF,
0x00, 0x00, 0x00, 0x09, 0x70, 0x48, 0x59, 0x73, 0x00, 0x00, 0x08, 0xF3, 0x00, 0x00, 0x08, 0xF3,
0x01, 0x7B, 0x0E, 0xD0, 0xB2, 0x00, 0x00, 0x00, 0x07, 0x74, 0x49, 0x4D, 0x45, 0x07, 0xE6, 0x01,
0x01, 0x0F, 0x2E, 0x2A, 0x52, 0xF5, 0x9B, 0x2D, 0x00, 0x00, 0x00, 0x46, 0x49, 0x44, 0x41, 0x54,
0x18, 0xD3, 0x85, 0x8F, 0x41, 0x0E, 0xC0, 0x20, 0x10, 0x02, 0x07, 0xB3, 0xFF, 0xFF, 0x71, 0x43,
0x2F, 0x54, 0xAB, 0xD5, 0xF4, 0xB4, 0x30, 0x6C, 0x48, 0x90, 0x01, 0x10, 0x10, 0xE5, 0x58, 0x82,
0xDA, 0xCB, 0x23, 0xA0, 0x7A, 0x94, 0xA0, 0x25, 0x7C, 0x6E, 0x17, 0x5E, 0x01, 0x0B, 0x28, 0xA4,
0x09, 0x5C, 0x7C, 0x3B, 0x3C, 0x01, 0xF3, 0x57, 0xBA, 0x01, 0x3E, 0x7D, 0x14, 0x20, 0x6B, 0x8C,
0xBB, 0x01, 0x94, 0x7E, 0x0C, 0x25, 0x4C, 0xF4, 0x08, 0x8B, 0x00, 0x00, 0x00, 0x00, 0x49, 0x45,
0x4E, 0x44, 0xAE, 0x42, 0x60, 0x82
Here is short video presentation:
  • kk99
    kk99 over 4 years ago in reply to amgalbu
    Thank you. Mainly it is behavior of M5GFX library and way of displaying of text on EPD display. You could speed it up by setting this mode:
    display.setEpdMode(epd_mode_t::epd_fastest);
    Here is video for last version:
  • amgalbu
    amgalbu over 4 years ago
    Nice project! Well done!
    Is it your choice to draw one day at a time os is it a limitation in the display Apis?
  • kk99
    One more update:
    calaendar2
  • kk99
    I have corrected displaying of last row which overlapped battery level indicator. Here is how it look like now:
    calendar2
