Member and Staff Blogs Video Test: Record multiple sources with OBS (2 cameras, Data Sheet, 2 instrument displays)
  • Date Created: 11 Apr 2020 10:12 AM Date Created
  • Views 3492 views
  • Comments 12 comments
11 Apr 2020
I'm trying out OBS as recording software.
It allows to mix sources on a single screen. In my case:
  • laptop camera for my face
  • USB cam for the bench, taped to a chair image
  • 3 windows: DMM display, eLoad display and datasheet in acrobat reader
  • record from Jabra wireless headset microphone.
There are some watchouts:
  • resizing the windows can make characters too small for reading (see eLoad window)
  • my layout is way too busy - less is more
  • Better cam for the bench would be appropriate.
  • It's not easy to switch in and out screens while recording. It breaks the flow. It may be better to stop recording, select screens, then continue
  • No mouse activity highlight (some recorders show an animation when you click the mouse, helps give feedback to the viewer).
  • glennvanderveer
    glennvanderveer over 6 years ago +4
    What you can also try is setting up your displays as different scenes. Then when you want to switch what you are recording, you would just pick a different scene. If you watch some of the streaming gamers…
  • ralphjy
    ralphjy over 6 years ago +3
    Interesting... I haven't used either OBS Studio or CamTwist. I'm just using the Logitech Capture program that came with my webcam. I'll have to give these a try.
    Jan Cumps over 6 years ago in reply to dubbie +3
    I downloaded it and tried. I haven't looked for a manual. After approx. half an hour of clicking around and looking at settings, I got to the point shown in the video. It originally errored when I tried…
    balearicdynamics over 6 years ago +3
    After testing both software, it seems that what you have used is good for the job, recording while the other is better (created for) real time video broadcasting.
    Jan, the "depression effect" happens to me too everytime I try a new setup. Don't desist, this is a great result. Enrico
    DAB over 6 years ago +2
    Interesting, I had not heard of this software. DAB
    Jan Cumps over 6 years ago in reply to glennvanderveer +2
    Yes. That requires thinking ahead though - something I never do when recording a video . I also need to check the sound. The volume isn't constant. I don't have that with the usual tools (a tablet for…
  • jomoenginer
    jomoenginer over 6 years ago +2
    Nice. I've used OBS for a couple of years now for my videos and it seems to work pretty good. You may need to fiddle with the Sound and the Video format to get the best options that fit your needs.
    Jan Cumps over 6 years ago in reply to balearicdynamics +2
    My first test was easy, using it as a way to capture my work in front of a PC. I just made a video while replacing the battery in a Keythley DMM6500. It's not a PC-focused activity. I use a tablet to record…
    balearicdynamics over 6 years ago +1
    Han good idea. If you have a Mac, try also the open-source camtwist studio ( CamTwist ) that has lot of more possibilities. Look at the videos on the site, it is very well done. Enrico
  • ralphjy
    Han good idea. If you have a Mac, try also the open-source camtwist studio (CamTwist ) that has lot of more possibilities. Look at the videos on the site, it is very well done.
    Enrico
