Member and Staff Blogs What "passes EMC" actually means on a Rockchip dev board — notes from the bench
  • Author Author: topeet
  • Date Created: 27 Nov 2026 4:27 AM Date Created
  • Views 9 views
topeet
topeet
27 Nov 2026
Hands-on notes from evaluating the iTOP-RK3588 and iTOP-RK3568 carrier boards. I had both boards through third-party EMC and FCC-VOC testing; this post is about what those reports do and do not tell you, and what I saw on the bench.
Why I ran the tests
On paper the RK3588 and RK3568 sit at very different performance points, but when you're building a product rather than a demo, the question that comes back is the same: will this board sit on a desk next to other electronics without becoming a radio transmitter? Datasheets do not answer that. An emissions report does.
So I sent the two carrier boards I was evaluating to an independent lab — BVT Testing (Shenzhen) — for radiated/conducted emission testing to both the EU EMC directive standards and FCC Part 15 Class B. The boards were tested as real systems: carrier board, display and the supplied power adapter, not as bare PCBs.
RK3588 EUT and display on the lab bench, with a ruler in frame so the board dimensions can be checked against the datasheet.
The setup the lab actually used
This is the part nobody shows in a product photo. For conducted disturbance the board runs through a LISN on a grounded bench; for radiated emission it goes into a semi-anechoic chamber with the display attached and the adapter in the loop. The test engineer chooses cable routing and operating mode — which is exactly why "it passed" on someone else's bench tells you less than you'd like.
RK3588 EUT powered up and driving the display during the test sequence.
Same arrangement for the RK3568 EUT.
One practical detail worth flagging if you ever send a board for pre-compliance: the photo set from the lab includes the power adapter, because the adapter is part of the emission path. Swapping to a cheaper supply later can invalidate a result that was otherwise clean. I learned that the hard way on an earlier project — a board that passed with its original adapter developed a conducted spike at around 150 kHz after we changed suppliers, and we had to rework the input filtering.
What came back
Both boards passed every applicable item. Full detail, including report numbers so you can verify with the lab:
RK3588 RK3568
EMC report BVTSZ202253546562ER BVTSZ220715980101ER
EMC standard EN 55032:2015+A11:2020 EN 55032:2015+A11:2020
Radiated emission PASS PASS
Conducted disturbance PASS PASS
Harmonic current PASS PASS
Voltage fluctuation / flicker PASS PASS
FCC report BVTSZ564984536596ER BVTSZ202208989757ER
FCC standard FCC Part 15:2016, Class B FCC Part 15:2016, Class B
Conducted disturbance Pass Pass
Radiated disturbance Pass Pass
The 3588 reports are dated September 2022; the 3568 EMC/FCC reports are dated August 2022. Report numbers are searchable through the lab's certificate lookup.
RK3568 carrier board, top view. The ruler is there because "190 x 125 mm" on a datasheet is easy to misread once a heatsink and connectors are fitted.
Read the scope before you quote the result
Two things I would want any engineer to know before treating these numbers as their own:
1. "Pass" is about emissions, not performance. These reports say nothing about inference throughput, decode sessions or sustained CPU temperature. If you're choosing between these SoCs for an edge-vision box, you still need your own benchmarks — run your model, record frames/sec and precision, and log idle and load temperatures with the cooling solution you intend to ship. I'm leaving those numbers out of this post deliberately rather than quoting someone else's markdown table as if I'd measured it.
2. A report is not a certificate. BVT states this explicitly in the document: the results apply to the specific sample submitted, not to every unit that will ever come off the line. Production changes — a different adapter, a different display cable, a relocated module — can move emissions enough that you need to re-check. Treat the report as evidence that the design can pass, not a permanent property of the part number.
Which board I'd actually pick
Leaving compliance aside, since both boards cleared the same emissions tests:
  • Single 4K HMI, light inference, tight budget → RK3568.
  • High-frame-rate capture or several displays, moderate budget → RK3576.
  • 8K media, quad display, heavier local inference → RK3588, and plan cooling
before you plan the enclosure.
The board family uses a carrier-plus-module layout, and that turned out to matter more than the SoC choice for production: you can start on a connector kit and move to your own carrier later without rewriting the software stack. The stamp-hole variant is smaller and better suited to a custom carrier once the design is frozen.
Documents
If you want to trace the numbers rather than take my word for them, the test reports are published with the board documentation. The boards themselves are at https://www.topeet.com.
Disclosure: I work with these boards and had the samples tested. The reports are third-party lab documents; the bench observations and failure anecdote above are my own. No performance figures have been substituted for measurements I did not make.
