Member and Staff Blogs What's new in fairy tech?
  • Author Author: scottiebabe
  • Date Created: 16 Nov 2023 1:35 AM Date Created
  • Views 2880 views
  • Likes 12 likes
  • Comments 19 comments
scottiebabe
scottiebabe
16 Nov 2023
The first set of fairy lights I purchased a few years ago had a very rudimentary embodiment. Just two AA batteries, an on/off switch, and a string of miniature LEDs on enamel wire.
I love the simplicity of the design... The design works well enough with disposable alkaline batteries. However recharge cells don't work very well on their own, as their combided state of charge voltage very quickly drops below the forward voltage of the white LEDs.
Fairy Tech 2.0
Browsing at the dollar store today, I found some new fairy lights which included some circuitry on a PCB. What could it be?
image image
Same general look and feel as before.
Now included is a three position switch!
The mysterious PCB
No sign of an inductor anywhere Disappointed. Just a
- 8-pin MCU?
- Watch crystal
- SPDT Slide switch
Fairy Tech 3.0
I can upgrade this new set of fairy lights with a boost converter module capable of operating of a single alkaline/Ni-MH cell
Module based on ME2188 https://file.elecfans.com/web2/M00/64/78/poYBAGMHOg-APsG0AAge4TQOpd0961.pdf
I bought a value pack awhile back thinking I would receive a selection of different output voltages. Nope, I got a bag of identical modules and each has a nominal output voltage of 5V. So, I added an additional 50 Ohm series resistor to limit the current to approximately 40 mA.
I am taking a bit of a gamble assuming the MCU is 5V rated. If it gives up the ghost, I'll replace it too.
All for now.
    beacon_dave over 3 years ago in reply to scottiebabe +1
    Out of the box they can also sometimes be a bit too bright for fast lenses with wide open apertures. Arducam do a low-cost F1.6 C-Mount lens which can be used with the likes of a R-Pi HQ camera for bokeh…
  • scottiebabe
    scottiebabe over 3 years ago
    Other Fairy Tech
    An IC specifically designed for Fairy Lights Heart
    https://www.shiningic.com/zh/productdetail.aspx?detailid=281&classid1=0101&classid2=010111
    I bought a set of solar powered fairy lights in the spring and found that IC inside.
    Hasn't given up the ghost yet...
  • scottiebabe
    Other Fairy Tech
  • scottiebabe
    scottiebabe over 3 years ago in reply to scottiebabe
    I took pictures in the spring but found someone else already posted about them, so check out their post about them
    https://westsideelectronics.com/fairy-light-teardown/
    This set has many animations. The leds are installed in alternating polarities along the string to allow for spatial effects in addition to PWM based intensity effects
