Member and Staff Blogs What's new in fairy tech?
  • Author Author: scottiebabe
  • Date Created: 16 Nov 2023 1:35 AM Date Created
  • Views 2872 views
  • Likes 12 likes
  • Comments 19 comments
scottiebabe
scottiebabe
16 Nov 2023
The first set of fairy lights I purchased a few years ago had a very rudimentary embodiment. Just two AA batteries, an on/off switch, and a string of miniature LEDs on enamel wire.
I love the simplicity of the design... The design works well enough with disposable alkaline batteries. However recharge cells don't work very well on their own, as their combided state of charge voltage very quickly drops below the forward voltage of the white LEDs.
Fairy Tech 2.0
Browsing at the dollar store today, I found some new fairy lights which included some circuitry on a PCB. What could it be?
image image
Same general look and feel as before.
Now included is a three position switch!
The mysterious PCB
No sign of an inductor anywhere Disappointed. Just a
- 8-pin MCU?
- Watch crystal
- SPDT Slide switch
Fairy Tech 3.0
I can upgrade this new set of fairy lights with a boost converter module capable of operating of a single alkaline/Ni-MH cell
Module based on ME2188 https://file.elecfans.com/web2/M00/64/78/poYBAGMHOg-APsG0AAge4TQOpd0961.pdf
I bought a value pack awhile back thinking I would receive a selection of different output voltages. Nope, I got a bag of identical modules and each has a nominal output voltage of 5V. So, I added an additional 50 Ohm series resistor to limit the current to approximately 40 mA.
I am taking a bit of a gamble assuming the MCU is 5V rated. If it gives up the ghost, I'll replace it too.
All for now.
    beacon_dave over 3 years ago in reply to scottiebabe +1
    Out of the box they can also sometimes be a bit too bright for fast lenses with wide open apertures. Arducam do a low-cost F1.6 C-Mount lens which can be used with the likes of a R-Pi HQ camera for bokeh…
    Looks like you are all set for some bokeh photography now Slight smile
    https://www.nikonusa.com/en/learn-and-explore/a/tips-and-techniques/bokeh-for-beginners.html
    I let Xmas cheer get the better of me last year and ended up with some USB powered light strings.
  • scottiebabe
    scottiebabe over 3 years ago in reply to beacon_dave
    That's wonderful! I can try, but LEDs don't have quite the same wonderful colors as the old tungsten mini-lights with painted glass.
    I have some neopixel fairy lights that might make some warm colors...
    Arducam do a low-cost F1.6 C-Mount lens which can be used with the likes of a R-Pi HQ camera for bokeh work for video as well as still photography.
    https://www.arducam.com/product/arducam-35mm-f1-6-mirrorless-c-mount-lens-for-raspberry-pi-hq-camera-with-c-cs-adapter-ln052/
    https://www.amazon.com/live/video/3fe10de00abf4e848156572658f5f50a?ref_=dp_vse_lbvc_2
    beacon_dave over 3 years ago in reply to beacon_dave
    That lens has a 12 blade iris aperture which makes for a smoother circle in the bokeh effect but you can also use masks over the lens to alter the shape of the bokeh effect. A heart-shaped mask can result in an image like this:
    https://unsplash.com/photos/hearts-bokeh-photography-fdYWSfH8N6Y
