Engineering Life
Engineering Life
Forum Dimmer repair
Join Engineering Life to participate - click to join for free!
  • Replies 77 replies
  • Subscribers 41 subscribers
  • Views 14346 views
Dimmer repair
wal_e
wal_e over 5 years ago
Hello everyone,
First of all I would like to apologize, I might certainly be in the wrong section, but I have been sent here by the Farnell technical assistance and to be honnest this place is a real maze for me image
So, I have been trying to fix a dimmer that went working only as a simple switch : OFF to ON max light directly. Following my researches it seems that the origin of my problem is a faulty triac and also - maybe - a capacitor ; I have tested both of the 2 fuses and they are ok.
The two original component are labeled:
- BTB04-600A
- CBB62B X2 0.033µF (250-280VAC) dimensions 40/110/56/C
My problem is that I can't find any of the exact two components and I have no idea what I can use to replace them as equivalent.
Any help is really appreciated
Thank you - very much - in advance.
W
    shabaz over 5 years ago +5
    Hi, If rotating the dimmer makes it turn the light on and off, then why do you think the triac is faulty? Couldn't it be the rotary potentiometer? (I don't know - I'm speculating). I'm not sure it is good…
    jw0752 over 5 years ago +4
    Hi Walid, If you only have off and on and when the dimmer is in the on position it is always at full brightness then the most likely problem is the Triac. You can test this with a continuity tester when…
  • wal_e
    wal_e over 5 years ago in reply to shabaz +4
    Hello Shabaz, Thank you for taking the time to answer. I found this diagnostic on the internet, it says that if the dimmer only works from OFF to ON max power it's a triac issue. As you can imagine this…
    jw0752 over 5 years ago in reply to wal_e
    Yes that looks like a good replacement.
  • wal_e
    wal_e over 5 years ago in reply to jw0752
    Here are the photos from inside the control:
    Please let me know if you have any remarks regarding their looks. I noticed that the inside is quite "greasy".
    Which part is the wiper ? the one attached to the plastic white rotating knob ?
  • wal_e
    The mesure of the outer strip is 0.555 when DMM is on 2 Mohm.
    Jan Cumps over 5 years ago in reply to wal_e
    That is normal, for a 500K potentiometer ...
  • wal_e
    wal_e over 5 years ago in reply to Jan Cumps
    That's what I thought too...so is there any way to fix it ? Should I clean the wipers with soft sand paper and rise them a bit ?
  • wal_e
    wal_e over 5 years ago in reply to wal_e
    So I tried cleaning the strips with a soft clothe, sanded sofftly the wiper and rised them a bit too...reassembled the control and tested the resistance between the two legs : 0.553 when DMM is on 2 Mohm. Resoldered the control and tested the switch...worked a bit as a dimmer, heard a few "sizzlings" but still managed to dim a few times then went back to ON-OFF only...
    Looks like you found the source of the problem at least and you can get a replacement control from EBay. Sorry for all the hoops you had to jump through but the failure of a control like this is very rare and not very high on my list of suspects.
  • wal_e
    I really had fun testing all the possible sources of this failure and learned a lot. Thanks to all of you for your time and help and especially you John.
    Take care.
    W
  • javagoza
    javagoza over 5 years ago in reply to wal_e
    Thanks to both of you, it's been great to see how you found the cause of the problem.
    The sizzlings are not normal. The capacitor (C1 in the schema you posted) normally drops the majority of the voltage before it reaches the potentiometer.
    My guess is that if you do not replace the capacitor, and buy a new potentiometer, you will have a repeat of the issue after replacing the potentiometer..
