Member's Forum New member Mats Önnerby introduction
  • Subscribers 630 subscribers
  • Views 238 views
Hi
The introduction letter asked me to write a little about myself.
I'm 50 year old and work as an IT specialist in at a food processing company. As a hobby I play with electronics and embedded systems.
In 2005 I created some robots. My first robot used a Basic Stamp. The second robot also used the Basic Stamp, but I needed more I/O and A/D conversion.
So I built a new board based on the Atmel ATMega163 that I used on the robot.
After the robot was finised, I started to work on a completley different project. I started to restore an old Ford Thunderbird 1964.
That project is now almost finished, so I'm returning back to electronics again.
My current project is that I'm trying to build a 3-phase motor driver that can drive a small 1kw motor. The motor is not really a motor but a modified car alternator.
I modified the alternator by removing the rectifier diodes and the voltage regulator. So now I have a 3-phase motor with an electroncic magnet as a rotor.
To get it to work I need to create a rotating magnetic field the same way as if it was an induction motor.
So I'm now creating a board with an Ardino, a driver circuit and 6 MOSFET transistors.
To do that I downloaded Eagle and started to use it. However the components I needed were not in the standard libraries of Eagle. So I started to search for more libraries, and that's how I ended up here.
/Mats Önnerby
  • element14jamie
    element14jamie over 12 years ago
    Hello Mats,
    Welcome to the Community, we hope you are enjoying it so far!  You may enjoy the Eagle Area or the Arduino area of the Community.
    Thank you,
    Jamie
