Member's Forum You Know You're an Engineer When...
  • Replies 198 replies
  • Subscribers 657 subscribers
  • Views 13108 views
  • engineer
  • imanengineer
  • newark
  • newark_element14
wpolk
wpolk over 11 years ago
We're asking you to complete this sentence: "You know you're an engineer when..."
Your input could be featured in an upcoming article on ImAnEngineer.com, Newark element14's newly launched website celebrating the ingenuity and impact of engineers!
We'll be choosing three of the most insightful and entertaining responses to send a much-sought-after bag of element14 swag to, between now and the end of July (don't worry if you're post is already in, we'll still consider it as an entry). T's & C's are here, and remember that you can drive the competition by casting votes for your favorite entries using the "Like" button on each post.
To bag your swag:
Step 1: Think deeply about the kind of traits that you feel typify the engineer's personality (and then check out the obligatory terms and conditions for the comp).
Step 2: Register, log in and comment on this discussion to tell the world about your favorite engineering personality quirks/disorders/idiosyncrasies.
Step 3: Make yourself a coffee and spend an enjoyable hour picking out the inspired (mostly hilarious) insights into your engineering identity, and hit the "Like" button on those that really resonate.
    "you're heart beat rises just by seeing a nut"
  • Capper
    Capper over 11 years ago
    You Know You're an Engineer When... The future "you" comes back in the time machine you will have built to ask you how to fix that thing that hasn't been invented yet.
  • jack.chaney56
    jack.chaney56 over 11 years ago
    You know you're an engineer when you find yourself solving the problems on the white boards while watching Big Bang Theory
    balearicdynamics over 11 years ago in reply to johnbeetem
    Minions are definitely off-topic !!!
  • johnbeetem
    johnbeetem over 11 years ago
    You know you're an engineer... when someone posts some interesting old technology and you immediately start reverse-engineering it, causing the discussion to go completely off-topic.  image
    • Vote Up +13 Vote Down
    balearicdynamics over 11 years ago in reply to Workshopshed
    Nice Andy. And if you put the full description of the device you find a lot of other pages. It seems that it is somewhere very simply to find, but it seems that it is not under production again... (it seems normal to me) image
  • Workshopshed
    Workshopshed over 11 years ago in reply to balearicdynamics
    Yes, looks like it should be straightforward, got all the data sheets and it's basically 9 chips and some resistors and capacitors. One of the chips is not the same as the other chips, labelled as Y1 in the solder mask.
    The data sheet seems to have the same setup.
    Worked out a bit more from the Epson serial number.
    I found a really helpful page based on that http://www.nikomp.com.pl/opisy/OEN00/OENH2802.htm
    Thanks for the image Andy, especially for the chip image
    The SED1180F was just a display controller including a shift register. 64 for the vertical lines was the base then eight controllers (seems just daisy-chained) manages eight horizontal display modules and the ninth is the one that interfaces with the controlling device. Or something like. Take a look to the two functional schemes of the IC below :
    The logic remain almost unchanged today. It seems not more complex than an Arduino LCD display controlled by 74HC595 daisy-chained shift registers image A good inspitration source.
    Enrico
    e14 Contributor over 11 years ago in reply to Workshopshed
    Whoa!  64×640.  That could be handy...
  • Workshopshed
    ...you find a very big LCD from the 1990s in the shed and wonder what would be needed to get it working
