Member's Forum Java/C Integration
  • Subscribers 630 subscribers
  • Views 158 views
Java/C Integration
element14Dave
element14Dave over 12 years ago
C is very good for programming embedded devices, but maybe a high level language like Java could increase productivity for some parts e.g. the application layer. If Java software components could be
integrated seamlessly into an existing software stack written in C, would you consider using it?
    shabaz over 12 years ago
    Hi Dave,
    Java or C++ are extremely useful to write large software applications (although there are also large applications written in C only), so in at least server applications it is maybe common to see these languages used, and I'm guessing the same could be true with Linux based SBCs too. For small non-Linux platforms I've only used C for a few reasons, mainly because the application may be small, and because I've not been sure what the state of the C++ compiler is for the microcontroller in question. But I'm no expert in this area, I'm not sure if the tide is changing and maybe many people might use C++ for small non-Linux platforms too. I'd be interested to know too.
