Member's Forum linear regulated power supply
  • Subscribers 633 subscribers
  • Views 834 views
Hey everyone so i recently seen on youtube you can convert an atx power supply from an older computer to a linear regulated power supply but they solder all of the 5v wires to the post as for all other voltages 3.3 12 -5 -12 but my question is could i make a solder bridge for the specific voltage and only use one wire per voltage
  • D_Hersey
    0 D_Hersey over 10 years ago
    Peter Oakes is correct but perhaps under-stating the case.  Fuses are a good idea, but you need some sort of crowbar to shut the supply down pronto if you expect to save the silicon from a significant over-potential.
  • uscdadnyc
    0 uscdadnyc over 10 years ago
    A bit late and a bit off Topic, but you might consider Switching Pwr Supplies (rather than Linear One) ACTUALLY an ATX Pwr Supply is a Switching Power Supply. If you have an Interest in Power Supplies (beyond just getting DC Power) there is a Course on Switching Power Supplies at the MOOC coursera.edu. Date & Times TBD And MOOC's are FREE unless you require Certification.
    Jumperone & great Scott booth have good videos on changing one to a lab power supply...
  • Robert Peter Oakes
    0 Robert Peter Oakes over 11 years ago
    All the 5V wires are connected to the same output of the power supply, the reason you use all (Or Most) of the wires is so you dont lose volts under high load. So to specifically answer your question, yes you could replace these wires with a single wire, just make sure it has the size to suite the current your going to draw from it. The same goes for all the other output voltages.
    Now to clarify something
    Your not converting the Computer Power Supply into a linear regulator. It is still a Switching Power Supply and still has several fixed output voltages. What you doing is converting it to use as a bench / Lab power supply.
    What you must be aware of is that most convert the MAINS to DC first then pulse power through the transformer to get your desired output voltages (I am drastically over simplifying this). so causion MUST be taken when modifying the internals of the power supply (LIke re-wiring it). Secondally, the 5V rails of these types of power supplies and other rails are able to output massive amounts of power (5V at 30A for example, 150Watts), if you accidentally short this to a lowly output pin of an Arduino, Raspberry PI etc you run the risk of blowing the @#$%@ out of it
    I would strongly recomend putting some kind of fuse or other current limit on the outputs in order to protect your connected devices
