Member's Forum Source measure unit & power analyzer
  • Subscribers 631 subscribers
  • Views 974 views
  • smu
Looking for recommendations for a DC power analyzer and source measure unit in the under $1000 range.  Current range: few uA to few amps, voltage range: under 30V, dynamic current measurement very desirable.
What do people use currently?
Tx
    0 michaelkellett over 11 years ago
    Well Nick, there is still nothing like enough information but I can give some answers.
    There are nice SMUs from Keysight (and  a really nice modular dc power analyser from Keysight at $20k ++) and Keithley but way outside your budget - so we'll forget them.
    A variety of people make devices intended for debugging.measuring micros (IAR and Hitex to name two)  - these are cheaper but limited in application :
    here's one of them:
    ISCOPE-ARM IAR Systems | Mouser
    I would use a scope and a meter with a decent lab power supply:
    You can buy a Keysight DMM with quite fast response  34465A34465A would be ideal but is outside your budget
    You could buy a Keysight data logger like  U2352AU2352A but it's nearly all your budget I have one(or a similar one but I never use it for this kind of thing
    What I do is put  a small resistor in series with the DUT (Device Under Test) and look at the voltage drop with the scope - sometimes you'll need to knock up a little amplifier to boost the signal.
    If you need to modulate the power supply voltage or current you are into big money again.
    You can measure the current with a current transducer but the dynamic range of the cheap ones is poor.
    Making one is an option but will eat a lot of time.
    0 e14 Contributor over 11 years ago in reply to michaelkellett
    Thank you Michael.  I have updated the question with more specifics.
    Can you be  a bit more specific - I can't help you re. the power analyzer (if it's mains power you mean bu perhaps you don't) but I know a bit about SMUs - if you means stuff like this:
    or
    but I don't think you'll get one new for anything less than $3500.
