Member's Forum wondering about this old transistor K45 6L3
  • Subscribers 632 subscribers
  • Views 1007 views
  • transistors
dad4five
dad4five over 10 years ago
Hey,
I'm looking for info on an old transistor I pulled out an old CB radio. Just curious really. It was labeled TRnnn on the PCB (don't recall the number). All the transistors are labeled TRnnn where the nnn is a sequential number of the transistor used in the circuit. This transistor has a metal case and FOUR leads. The four leads got me curious. I thought maybe one of the leads just grounds the metal case. I was looking at packaging types and found this TO-33 case type.
It has four leads. The example shows a darlington pair with two different base inputs. Maybe that is what this is?
I searched a few datasheets sites but no luck. I sure it has been discontinued long ago.
Any ideas suggestions on where to look.  thanks
  • dad4five
    0 dad4five over 10 years ago in reply to jw0752
    thank you very much.  This community board was much more helpful than my google searching.
    0 jw0752 over 10 years ago in reply to clem57
    Hi Clem;
    He is fine, just at the stage in life where he is trying to juggle too many balls at the same time. I have never seen anyone work harder than he does and I am very proud of him. I just hope I live long enough for him to get to retirement age so we can play at electronics a little before I'm out of here. Thanks for asking.
  • clem57
    0 clem57 over 10 years ago in reply to jw0752
    wow! jw0752 you have a plethora of facts and information. You truly amaze me. BTW, How is your son since he has been quiet for a while.
    Clem
    Hi W Ellena,
    The transistor is probably a 2SK45 which is an N CH JFET. It has 4 leads and one of then is attached to the cast and acts as shielding. I found that these transistors were used in the RF amplifier sections of CB radios when I serviced them years ago. Here is a DATA sheet for an NTE equivalent.
    http://www.nteinc.com/specs/400to499/pdf/nte456.pdf
