Member's Forum Python installation
  • Subscribers 632 subscribers
  • Views 555 views
Python installation
Where to get beaglebone Debian distribution ? How to install python,matplotlib,tkinter,tk.
    I misspoke. I can now install matplotlib but I get the error:
    "from matplotlib.backends import _tkagg
    ImportError: cannot import name _tkagg"
    when I try to run my Python code. So apparently I don't have tkinter or tk or something installed and can't figure out how to get it.
    johnbakeree@blogspot.com
    0 e14 Contributor over 10 years ago in reply to clem57
    Thanks Clem. My BBB came with Debian bone47. I was able to run my Python code that has a GUI using Matplotlib, Tkinter, etc with a graph, buttons, text boxes and all that. I have the 4D Systems 4DCAPE attached to my BBB.
    Then I was trying to use the Adafruit BBIO for PWM and ADC but had problems so flashed the BBB with a newer Debian, bone79, and since then haven't been able to get my Python program to run. I couldn't install Tkinter and tk etc. Now I cannot even install Matplotlib: when I try to install it, I get an error that Matplotlib cannot be found. Now I am trying to install Python, Matplotlib, Tkinter, tk etc on the Debian bone50, it's 3.8.13 bone50.
    I ran these steps but get error:
    So I'm still dead-in-the-water. That tkagg seems to be the problem and cannot find a solution. I found suggetsions from stackoverflow but their suggestions don't seem to help (http://stackoverflow.com/questions/32188180/from-matplotlib-backends-import-tkagg-importerror-cannot-import-name-tkagg/3…)).
    With internet connection:
    sudo apt-get install python
    sudo apt-get install python-numpy
    sudo ntpdate pool.ntp.org
    sudo apt-get update
    sudo.apt-get install build-essential python-dev python-setuptools python-smbus -y
    which dtc
    sudo pip install matplotlib
    sudo apt-get install python-tk
    sudo apt-get install tk-dev
    sudo apt-get update && apt-get install  python-serial  python-setuptools python-dev  python-smbus  python-pip
    pip install --upgrade PyBBIO
  • clem57
    0 clem57 over 10 years ago in reply to clem57
    After building a Debian system, you should have python.The others will be updated when you use Linux package manager called aptitude. Read about and ask if you get stuck.
    Clem
  • clem57
    Check BeagleBoard.org - latest-images for download of images. I would try one without using eMMC first and verify it works. Once you flash, no way to go back without a re-flash. Directions are here -> https://beagleboard.org/getting-started#update. Read first and understand. Then try. Post here if you have any doubts.
    Clem
