Member's Forum Pulse circuit help
  • Replies 12 replies
  • Answers 3 answers
  • Subscribers 633 subscribers
  • Views 1647 views
  • opamp
  • led
  • 555
Pulse circuit help
pathfider1998
pathfider1998 over 10 years ago
First question: I need to make a circuit, using generic OP-AMP, that takes 5V and audio signal (mono/L/R) and flashes LED every peak.
The OP-AMP can be anything, but it must follow 8-pin layout. (Not surface-mount components)
Second question: I need to make a circuit which outputs high-pitched blips (or continuous pulse) using 555 timer. I had this circuit diagram but I lost it.
  • peterjcs23
    0 peterjcs23 over 10 years ago
    Q1. Don't use an opamp use a comparator.
    MAX9140EXK+T - MAXIM INTEGRATED PRODUCTS - Analogue Comparator, Rail to Rail I/P, High Speed, 1, 40 ns, 2.7V to 5.5V, SC…
    And use an IC adapter to get DIL legs.
    0 shabaz over 10 years ago
    Hi Phil,
    You can find all this type of stuff here:
    1 - 200 Transistor Circuits
    and
    101 - 200 Transistor Circuits
    and
    50 - 555 Circuits
    and
    100 IC Circuits
    Hit Ctrl-F and type a keyword or two, and you're bound to come up with these circuits, or ones you can adapt to your needs.
