Member's Forum Groundplane to edge of PCB
  • Subscribers 631 subscribers
  • Views 575 views
I can't get ground planes to go all the way to the edge of the PCB.  When I draw the polygon I have the width set to 0.01 and the isolate parameter set to zero.  If I draw the polygon to match the border area (as defined in the dimension layer) and do the ratsnest command the ground plane shrinks and leaves a gap between it and the board edge (0.05 in. in my case).  What do I need to do to eliminate this gap (margin).
  • kulky64
    0 kulky64 over 10 years ago
    Go to DRC, Distance tab and set Copper/Dimension to 0.
