Member's Forum Laptop Battery
  • Subscribers 632 subscribers
  • Views 642 views
Laptop Battery
stburrell
stburrell over 9 years ago
Okay, so my laptop battery sucks. It's not old or defective, it just sucks. How possible would it be to solder another batter to the wiring for it and gice my computer 2 internal batteries? I have the room for it, I just want to make sure that my laptop won't blow up or anything. The battery is up top in pink plastic, and the space for the other is at the bottom.
    0 DAB over 9 years ago in reply to stburrell
    Hi Seth.
    The problem with just putting another battery in parallel can be very complex.
    You have issues about different chemistry, capacity, internal dynamic resistance changes, etc.
    Go to the TI site and look at their power design section.  They have a lot of good advice and circuits showing how to combine multiple power sources to a common mode.
    Just strapping two batteries together is a great way to release the magic smoke, not to mention start fires and turn your laptop into a mass of burning plastic.
  • stburrell
    0 stburrell over 9 years ago in reply to volly
    Not sure without opening it. But I have a screenshot of someone taking it apart. I can't seem to add a picture, but here's the video and you can read it. https://youtu.be/rXMY6nNvJrI
  • volly
    0 volly over 9 years ago
    stburrell, What is the current power rating and part number of your batteries and can you check the number of units and are they soldered/wired in series ?
    Well...never buy the Chinese make..
  • stburrell
    Would it be a problem if I just bought anotherbattery for my laptop, the exact same one I have, and solder that? Or will that cause problems? What steps should I take in persuing this project? I do not trust buyingbatteries with higher power online because I've been pretty much screwed more than once and ended up with batteries that were lower than my original. Thank you for responding!
  • volly
    stburrell. Welcome to our great E14 Community.
    To answer the first part of your question, It is quite possible to solder another battery to your current setup.
    Just make sure that you do not add the new battery in series to the current setup as this will increase the voltage way above the laptops power rating and might just damage the Laptop.
    You may want to check your current batteries for a better rated compatible batteries that has same voltage but pack more power (mAh), instead of adding another, so doing increasing
    the risk of damaging your Laptop. At the same time you will get better power performance out of the better higher powered batteries.
    hope this help.
    Yunus.
