Member's Forum Easy way to do 350Hz Oscillator?
  • Replies 13 replies
  • Answers 9 answers
  • Subscribers 631 subscribers
  • Views 1554 views
alienozi
alienozi over 8 years ago
First of all, if the place of my thread is wrong please guide me to correct one.
Greetings,dear internet people and fellow electronics hobbiysts.
Me and my friend work on a project which requires a 350Hz Oscillator in order to function properly.
However we could only "try" this on schematic and theoretically. The transistors we use have different hfe and this makes our job harder to obtain the theoretical circuit in real life.
My inquiry is that if any solutions on how to do this easier exists, please do inform me. I wonder if there is a crystal Oscillator way or maybe an IC? And please do consider the fact that I'm only a high school student who possesses little knowledge and who is new to electronics.
Thanks!
  • alienozi
    0 alienozi over 8 years ago in reply to jw0752
    Thanks, John
    We are trying to obtain a sine wave of 350 Hz at a Pk-Pk Voltage of 5V. Output must be continuous (or a good enough one).
    I do have an oscilloscope, a Tektronix TDS 2002.
    Here are the circuits we've worked on so far: (sorry for the quality of the pics and circuits )
    0 dougw over 8 years ago
    Check this out - it explains how to pick components to get your frequency with a 555 chip:
    Nuts & Volts Magazine - For The Electronics Hobbyist
    0 jw0752 over 8 years ago
    Hi Oguz,
    I have a few questions for you. What type of wave output are you seeking, Sine, Square or other? How are you testing the frequency? How stable does the frequency have to be? Can you supply the schematic or drawing of the circuits that you have tried so far? This is a low audio frequency and should not be very hard to produce. If the stability is not too critical you should be able to use a resistive or capacitive trimmer to adjust the frequency once you have established a close approximation with fixed passives.
    There are many guys on the site that are real experts but I know they will be able to give you better suggestions if they understand better what your parameters and application are.
