Member's Forum Soldering to X
  • Answers 2 answers
  • Subscribers 631 subscribers
  • Views 778 views
  • whatsinthebox
  • onoff
  • latch
  • soldering
  • halp
Soldering to X
malus_lupus
malus_lupus over 8 years ago
I hear copper is the best thing to solder to my question is can you solder to copper screws?
You see for a dirty switch I would just make an everyday latch let gravity do the work and such however I cannot really figure out a good method besides using a screw. From past experiences soldering onto typical screws is quite challenging, to say the least.
Here is an image to maybe help.
  • malus_lupus
    0 malus_lupus over 8 years ago
    Copper and Brass thank you. I have a flux pen and I do have a welding soldering iron that someone bought but found useless and gave to me. My soldering iron can probably do it considering how small the screws will probably be though. The above box is about 2 inches by 2 inches if not a little more. This could make other things work out way better as well if I can get some copper screws instead of having wires sticking out everywhere some copper pins maybe... Yeah. Then it could just plug into each other.
    0 dougw over 8 years ago
    You can solder to copper or brass as long as the metal is clean (not oxidized) and you have enough heat. As Gene mentions, flux helps.
    0 genebren over 8 years ago
    Justin,
    You should be able to solder to a copper screw, but you might need a larger iron (and least large tip) to get enough heat into the screw for the solder to flow. Adding flux to the screw might also improve the heat transfer and also keep to screw from oxidizing while you are heating it.  You might also try something like a ring or spade lug to attach the wire to the screw.
    Gene
