Member's Forum With the superconductors in the future, the AC voltage be obsolete?
  • Answers 2 answers
  • Subscribers 631 subscribers
  • Views 919 views
  • element 14
  • power systems
ojed81
ojed81 over 6 years ago
With superconductors in the future, will the alternating current "AC" be obsolete?
  • ojed81
    0 ojed81 over 6 years ago in reply to DAB
    thanks
    0 DAB over 6 years ago
    You will always need AC for long distance power transmission.
    Now if you connect superconductors with a localized battery powered by wind an solar, you can greatly reduce the long distance power needs and make the overall power grid more robust.
    0 michaelkellett over 6 years ago in reply to Jan Cumps
    For long distance high power transmission DC over normal conductors is more efficient and ultimately cheaper than AC - despite the horrendous cost of the power converters.
    There's a long Wiki article about it here:
    https://en.wikipedia.org/wiki/High-voltage_direct_current
    But superconductors won't replace AC for lower power (ie under 100MW) stuff any time soon because transformers are so relatively cheap and reliable and the losses aren't that bad.
    And anyway - we don't have useful normal temperature superconductors.
    0 Jan Cumps over 6 years ago
    Do you mean that transmission lines will be made with superconductor wire, and that transformers will be replaced by DC:DC converters?
    I think no. The AC way is inherently cheaper to transport. And up till the foreseeable future cheaper to level-transform ...
