I am looking for IR TX and Rx which can easily work in outdoor .
At present I am using IR rx diode , but it's not working in day time.
Please suggest me which IR TX and Rx should be used for outdoor.
You will likely need to do several things as already suggested:
As Scott mentioned. Regular IR LEDs won't work in the sun. Your receiver picks far more IR from the sun than your LED source.
You may have to try an IR Laser. Check these two.
https://www.amazon.com/Focusable-Infrared-4-2v-5v-Module-12x40mm/dp/B00S9JW7WI
https://www.amazon.in/Generic-3-3mm-Infrared-Module-Generator/dp/B01GCT3S2Y
or Get any Laser which is around 800nm.
Aswin
Your problem is not easy to fix. The sun is a very strong source of IR.
You can try and shield the receiver with a black tube and use a laser diode source.
