Member's Forum Frustrated
  • Replies 15 replies
  • Answers 3 answers
  • Subscribers 631 subscribers
  • Views 2926 views
Frustrated
stumpedandfrustrated
stumpedandfrustrated over 4 years ago
Ok so, I am a newbie to the tech world by about 10 years. Self taught and have a ton of learning left to go. My question is...
I have been hacked, took a long time to figure out how it kept happening again and again, with new devices accounts passwords new home networks etc etc.. HOW do I locate the hacker?? The person in question is someone I know, has taken administrative control of all my devices, has remote root access and uses multiple accounts on their visited sites, which normally sends me to a redirect when I get to close. I have now gotten passed the sherad, and know who it is. I just want to catch this person. Please someone guide me in the right direction.
  • cstanton
    0 cstanton over 4 years ago in reply to Jan Cumps
    You snuck in just as I was about to.
    0 Jan Cumps over 4 years ago in reply to stumpedandfrustrated
    I suggest locking this thread as this is relationship troubles. Should be handled by the ex-partners in the intimacy of their lawyer's offices.
  • cstanton
    0 cstanton over 4 years ago in reply to stumpedandfrustrated
    stumpedandfrustrated Given US law you're probably better off not posting claims or allegations against person or persons on this website or elsewhere and you should consult with legal advice such as a lawyer. In fact it would be worth your while talking to a lawyer anyway and start any such audit or evidence trail as is necessary, as I said, digital forensics, but also you may be liable for whatever you post on here.
    I believe other members have been good enough to advise you on steps to take as well, but there's little more we can offer in ways of help with this I believe.
  • stumpedandfrustrated
    0 stumpedandfrustrated over 4 years ago in reply to cstanton
    Thank you very much for your insight, and depth of paths to follow. Some of which I have started down. I have been holding back on the depth of information from my situation due to the extent that the person hacking me has been labeled 1 of the top 50 female code writers in the country. If what she is doing could be used again to harass someone else or worse I don't want to be responsible for making the info known. She was also my wife for over a decade and it was this website in its own that I discovered in a hidden favorites folder on the old phone I found of hers dated 10/5/21 so I'm assuming she is a member of this site. The harder I investigate the harder I'm pushing her to stay on top sooner or later she will make a mistake that will help me catch her and press charges.
  • cstanton
    You're not giving a lot of information to go on, or what behaviour is happening exactly.
    The first port of call is typically to disconnect from the internet, put your devices into airplane mode.
    Then reset devices to factory defaults.
    I mean it depends how 'deep' you're thinking this 'hack' to have happened to, it's not common that hacked devices can survive being reset to factory defaults, but it also depends on what devices have been 'hacked' and what behaviour you're seeing.
    To find out what's happening you need a way to monitor your devices using a 'known good' or 'known safe' setup that can monitor network activity, view all traffic, and effectively 'hack' your setup to see how it's behaving.
    Though I'm guessing you're on a typical home setup, with a gateway/router provided from your internet provider, and home devices/mobile phones.
    Any lost accounts should be taken up with the respective providers/companies and any unknown or foreign devices from your network and home should be removed/unplugged.
    If you're unsure how to do any of this, disconnect everything and hire an 'infosec' company to check it out for you, or a 'penetration tester' to do a security audit of your kit, at the very least hire an Information Technology specialist that can isolate, identify, backup and clean your equipment.
    Law enforcement obviously varies depending on your country and state. If you want to take action against whoever's doing it, you need 'digital forensics' to capture and analyse what's going on with your equipment, which'll be a specialist law enforcement team or again, infosec.
    0 dougw over 4 years ago
    It sounds like you need to fix your router or get a better one.
    https://www.tomsguide.com/us/home-router-security,news-19245.html
    I think we arrived in crazy land now.
    0 stumpedandfrustrated over 4 years ago in reply to colporteur
    Thank you Sean Conway
    that is precisely the question at hand.
    I just recently found a 12 year old lg touch screen that ran on a net 10 pre pay. It was a 20 dollar phone 12 years ago. It belonged to the hacker. It was in an old back pack of mine in a closet uncharged for the last 10 years. When I stumbled across it in the closet a couple of weeks ago it was up and running and has many apps loaded into it that are updated to match the Samsung galaxy s8+.. I was recently told that is impossible and not true.. yet I have it in my possession. I believe that is to hidden Backdoor. However I want it to be researched before I move forward with it.
  • colporteur
    0 colporteur over 4 years ago in reply to stumpedandfrustrated
    What have you done to stop the attacks?
    It appears there may be a number of attack vectors used to target you. Devices in your network, you phone devices, IoT devices (i.e. TV) and external resources you use. Shutting the door on one is ineffective without all the other doors closed also.
    If this is a targeted attack as you suspect, what attempts have you made at closing doors?
    Again, like the other answers you are absolutely correct. The problem is the point of entry or many backdoors for entry into the network and the devices. When I get a new device " NOT using anything " tied to the previous device or network... within an hour the new device has been compromised. Once administrator owner has been hijacked, the complete OS can be made writable, so that to the common user looks as if everything is running as it should, but to follow background usage, and you see 500 different DNS running " each on a different network" " T-Mobile, Net 10, Sprint, Etc"... then you look at your Task manager, and the CPU is operating at more processing memory that your device is capable of performing. The Data is spiking to 1.5Gb in an hour and your not even touching your device. You find the data usage in your system files in an empty cache file or 100 empty cache files per process. For each process I have recorded " remote network change for each process. All system apps have been made to look and present the app as it should, but in fact is actually some 3rd party programming app that has been manipulated to function specifically to the hackers needs. I've been called paranoid, crazy, even delusional over the last 10 years. The few things that I have mentioned are just the typical everyday activity that surrounds my life. I have run new phone out of the box side by side tests to prove what I say here is fact. All security access was professionally set up and Norton 360 with life lock installed both devices. Still within a short time the device has a mind of its own. I have detailed litterateur of how this is possible and schematics to show the facts. So top security, new perfectly well running devices, and professional set up, puts the poor security theory to rest.
    All ideas thoughts feelings criticisms are welcomed.
    ty
