Member's Forum Electronic CAD - Which is the best value?
  • Replies 11 replies
  • Subscribers 597 subscribers
  • Views 2704 views
  • electronic CAD
  • cad
dougw
dougw over 3 years ago
To get an idea of best value, you need to convert your CAD time to money and add the cost of the product to get total cost. Then divide your output by the total cost.
Altium Circuit Studio $688
Cadence OrCad $530
Autodesk Eagle $645
Siemens Mentor PADS $499
Easy-PC $360
KiCad $0
Other - there are lots of others to consider.
It would seem that CAD is not in the Technologies list on this forum.
    michaelkellett over 3 years ago +3
    There are many other low cost options. I use and strongly recommend EasyPC from Number 1 systems. It's cheap and above all simple. No good for ultra fast wiggly impedance and ns matched tracks but…
  • Andrew J
    Andrew J over 3 years ago +2
    On that list alone, you'd have to say Kicad surely! I suppose if, say, Altium had a needed feature not present in KiCad with no work around, then Altium is the best value. I'm probably biased in any case…
    Jan Cumps over 3 years ago in reply to michaelkellett +2
    michaelkellett said: Don't be misled by PCB systems that offer built in simulation LtSpice (from AD) or SuperSpice are free. I've never found the integration of a simulator with the pcb tool to be worth…
    shabaz over 3 years ago in reply to Jan Cumps
    An example of Multisim in use (this is a slide from a talk I was supposed to give to some Amateur Radio people at some point, so I had it pre-prepared).
    The red and yellow blobs on the schematic are just graphics I added to show where the red and yellow output on the oscilloscope view came from (it's showing frequency conversion from the mixer). On the left you can see the divide-by-4 and quadrature signal generation.
