    • Avnet Boards Community
Member's Forum A Soldering Iron for Christmas
  • Replies 21 replies
  • Subscribers 548 subscribers
  • Views 4084 views
scottiebabe
scottiebabe over 2 years ago
With a few words of encouragement from shabaz and baldengineer I snuck this bad girl into the Christmas tree!
A USB-c powered portable soldering iron!
 image image
Fully assembled it has a similar form factor to my weller wxmp
With the temperature set at 300 degC it struggled a little to melt leaded solder on a copper clad board.
When I adjusted the temp to 330 degC the same temp I use on my weller wxmp, Id say its thermal performance felt similar (no scientific evidence).
The only obvious criticism I have thus far is the included silicone USB cable is a little on the short side. If the cable was 30 cm longer, I think it would be long enough. I am hopping to find a powerbank that will power this iron, at which point the USB cable length would not be an issue.
It also didn’t include a travel or storage pouch…
But that is also okay, I think I am going to try and put together an electronics first aid kit (I have the soldering iron covered).
    Jan Cumps over 2 years ago +5
    what a time to be alive https://youtu.be/qCC941xKuBs
  • scottiebabe
    scottiebabe over 2 years ago in reply to colporteur +3
    I purchased mine through amazon and had it not been for the eggnog in the moosemug I probably would have noticed the $15 off coupon, o well. https://www.amazon.ca/gp/product/B089ZSG7XG/ The complete…
  • scottiebabe
    scottiebabe over 2 years ago +3
    If one was proficient in the mechanical side of things, you could DIY your own USB soldering iron (others have). I just tried heating up one of my weller tips which like the TS80P use a 3.5 mm TRS jack…
    • Vote Up +5 Vote Down
