Member's Forum FNB58 USB Power Tester
  • Replies 31 replies
  • Subscribers 559 subscribers
  • Views 9315 views
scottiebabe
scottiebabe over 2 years ago
Soft 404
  • charlieo21
    charlieo21 over 2 years ago +5
    Here is a data logger software for this device. It will be interesting to see a teardown of this USB power tester.
  • ralphjy
    ralphjy over 2 years ago in reply to scottiebabe +4
    You'd make a great salesperson . I developed a need for a USB-C tester, so I followed your lead. I did buy the Bluetooth version even though on Amazon it says that it doesn't support iOS yet. I'll…
  • scottiebabe
    scottiebabe over 2 years ago in reply to ralphjy +4
  • ralphjy
    Did you get the version with Bluetooth?  I was wondering how well the app worked.
  • Gough Lui
    Gough Lui over 2 years ago
    Looks handy to have around ... I should probably have one just to use as a trigger. Let's see if I ever get around to getting one.
    - Gough
  • robogary
    robogary over 2 years ago
    Found your socks scottiebabe  https://www.popsci.com/now-you-can-see-all-space-junk-floating-around-earth-real-time/
  • baldengineer
    baldengineer over 2 years ago
    Does it come with a USB-A extension cable? (So that it doesn't block other ports on a laptop).
  • CargoCultScientist
    CargoCultScientist over 2 years ago
    Thank you for sharing your experience with the USB power tester. It sounds like a useful gadget for basic validation and troubleshooting of USB power supplies, despite the limitations of its accuracy and lack of calibration options. The additional features like the rudimentary oscilloscope for bus ripple sampling and the ability to query and trigger USB power delivery profiles add value to the device.
    it's unfortunate that you're experiencing issues with your Windows 10 desktop. You may want to try the following steps to troubleshoot the issue:
    1. Check if the software is compatible with Windows 10 or if there's a specific version for Windows 10 that you need to download.
    2. Make sure your Windows 10 desktop is up-to-date with the latest updates and drivers.
    3. Try running the application in compatibility mode for Windows 8.
    4. Check if there are any known issues or solutions on the manufacturer's website or online forums.
    If you still encounter issues with the Windows 10 desktop, you might want to reach out to the manufacturer's support team for assistance.
    I hope this information is helpful
  • scottiebabe
    scottiebabe over 2 years ago in reply to baldengineer
  • baldengineer
    baldengineer over 2 years ago in reply to scottiebabe
    Boooo.
    Not a deal breaker, but I was hoping.
    Seems way more competent than the $20 USB meters I've used in the past. (I"ve added one to my wishlist for future-James to buy accidentally.)
  • scottiebabe
  • wolfgangfriedrich
    wolfgangfriedrich over 2 years ago in reply to scottiebabe
    Ha, if I search for TPA626, the 1st PDF datasheet link is for the INA226! Thinking
  • scottiebabe
