Member's Forum How often have you come across the parts per thousand symbol?
  • Replies 11 replies
  • Subscribers 594 subscribers
  • Views 1715 views
scottiebabe
scottiebabe over 3 years ago
Soft 404
  • CargoCultScientist
    CargoCultScientist over 3 years ago +4
    Well, it's super common in Europa related to blood alcohol content, but as a scientist or engineer you can come across it quite often. We measure water salinity in this way, thermal expansion usuallly…
    Jan Cumps over 3 years ago +3
    It's the go-to Unit Of Measure for alcohol tests and related laws here
  • dang74
    dang74 over 3 years ago +2
    Wow. I never knew about that symbol. And now that my eyesight is getting worse with age I really do fear that one day I will mistake it for a percentage sign.
    Well, it's super common in Europa related to blood alcohol content, but as a scientist or engineer you can come across it quite often. We measure water salinity in this way, thermal expansion usuallly comes in per million per degree Celsius (ppm/°C), but can also be represented as per mille (‰) when multiplied by a factor of 1000. Same with engineering strain, as a measure of deformation when an object is subject to stress. And of course tolerance of stuff the we order in a machine shop, if we need something for precision instruments, every critical measurement must be submitted with tolerances for dimensions, measurements, or performance characteristics. For example, a bearing with a radial runout tolerance of 3‰ would have a permissible deviation of 3 parts per thousand from its nominal dimension.
