Member's Forum How often have you come across the parts per thousand symbol?
  • Replies 11 replies
  • Subscribers 629 subscribers
  • Views 1867 views
scottiebabe
scottiebabe over 3 years ago
Soft 404
  • CargoCultScientist
    CargoCultScientist over 3 years ago
    Well, it's super common in Europa related to blood alcohol content, but as a scientist or engineer you can come across it quite often. We measure water salinity in this way, thermal expansion usuallly comes in per million per degree Celsius (ppm/°C), but can also be represented as per mille (‰) when multiplied by a factor of 1000. Same with engineering strain, as a measure of deformation when an object is subject to stress. And of course tolerance of stuff the we order in a machine shop, if we need something for precision instruments, every critical measurement must be submitted with tolerances for dimensions, measurements, or performance characteristics. For example, a bearing with a radial runout tolerance of 3‰ would have a permissible deviation of 3 parts per thousand from its nominal dimension.
    dougw over 3 years ago
    I don't recall seeing this but there is a chance of about 152 micromorts that I have seen it before ....Relaxed
  • Andrew J
    Andrew J over 3 years ago
    Never noticed that before!  Mind you with my eyesight....
  • charlieo21
    charlieo21 over 3 years ago
    I have seen it before but the most common is ppm.
  • dang74
    dang74 over 3 years ago in reply to beacon_dave
    Indeed.  LOL
  • beacon_dave
    beacon_dave over 3 years ago in reply to dang74
    It could be the new Snellen chart
    'cover your left eye please...'
    'and now the right eye...'
  • ralphjy
    ralphjy over 3 years ago
    I would have missed that in the spec table.  Use of it that way seems to obfuscate things based on the way instruments are normally spec’ed.  Or maybe that’s a typo (misuse of a symbol).
  • kmikemoo
    kmikemoo over 3 years ago
    Never.
    Jan Cumps over 3 years ago
    It's the go-to Unit Of Measure for alcohol tests and related laws here
  • dang74
    Wow.  I never knew about that symbol.  And now that my eyesight is getting worse with age I really do fear that one day I will mistake it for a percentage sign.
