Member's Forum Movement Analysis of Cue Sports
  • Subscribers 627 subscribers
  • Views 1121 views
JMAC7
JMAC7 over 3 years ago
New to forum. Have previously used accelerometer to analyse a professional cue sports player. Anyone here or know of similar tech applied to cue sports.
John from Brisbane
Retired Electrical/ Biomedical Engineer
  • JMAC7
    JMAC7 over 3 years ago in reply to dougw
    Thanks will reply later as many excellent aspects embedded in your comments and links.
  • JMAC7
    JMAC7 over 3 years ago in reply to charlieo21
    Had a quick search and no related projects. You are on to something as while the cue does the work the errors are in delivery all part of biomechanics. Elbow shoulder wrist head movements. Tension is a factor as in the pressure of competing and clutching jabbing as opposed to smooth timing. Did see some dot systems that use internal accelerometers and video calibration though for semi professional at $15k. Your idea though could work out cheaper and may even capture cue movement from video footage. So could record signature swings of professional players and compare to or copy for novices to learn. Timing appears a critical requirement for position control and importantly for eliminating sidemovement in the practice swings. Thanks for suggestions.
  • JMAC7
    JMAC7 over 3 years ago in reply to cstanton
    Thanks. Snooker was my original purpose as pockets less forgiving and distances involved on large 12' x 6' table. Since my experiments many years ago now a few commercial products though on has had no chips for two years with next shipment in August. Has this impacted Engineering projects for anyone here. My original accelerometer was from Analog Devices via a development kit.
    dougw over 3 years ago
    Lots of work has been done on cue control. It is all about speed and direction. Accelerometers are often used because they are easier to implement than velocity sensors, so the acceleration must be integrated to determine speed. If the mass of the cue equals the mass of the ball, the cue should stop on impact and the ball should acquire the speed of the cue, but of course the hand interferes with this relationship, as does the locus of impact.
    https://billiards.colostate.edu/faq/stroke/acceleration/
  • cstanton
    cstanton over 3 years ago
    Hey JMAC7 , welcome to the Community!
  • charlieo21
    charlieo21 over 3 years ago
    Welcome! I´m sure you can do object detection/tracking, check OpenVINO
