Ask an Expert Forum How to use an IC with this packaging
  • Replies 12 replies
  • Subscribers 296 subscribers
  • Views 2675 views
  • help
  • prototyping
  • soldering
See a helpful answer?
yosoufe
yosoufe over 2 years ago
I have an IC with the following packaging. It is weird that it has two sections. How should I use it? Can I just cut the second part?
Here is the datasheet of the IC: https://www.allegromicro.com/~/media/Files/Datasheets/ATS668-Datasheet.ashx
I am still prototyping with it. Like on a breadboard or like that.
  • Gough Lui
    Gough Lui over 2 years ago +7
    You would cut off the bar and that would leave you 2.4mm pitch. If you cut above the knee, then that leaves you with 1.27mm pitch. - Gough
    shabaz over 2 years ago +3
    Hi, You can just bend or cut it off. It's supplied like that because some manufacturers may mount these sideways on a PCB, and the leads might accidentally be bent if it wasn't on that strip, which would…
  • yosoufe
    yosoufe over 1 year ago +3
    I ended up using it like this Keeping the protection as is on the PCB.
    You can just bend or cut it off. It's supplied like that because some manufacturers may mount these sideways on a PCB, and the leads might accidentally be bent if it wasn't on that strip, which would make it harder to solder by machine.
  • Gough Lui
    - Gough
    • Vote Up +7 Vote Down
  • yosoufe
    yosoufe over 2 years ago in reply to shabaz
    Thanks.
  • yosoufe
    yosoufe over 2 years ago in reply to Gough Lui
    Thanks. Slight smile
  • colporteur
    colporteur over 2 years ago in reply to Gough Lui
    I've not seen that level of lead protection and/or pin spacing option. Learn something today.
  • yosoufe
  • anniel747
    anniel747 over 1 year ago in reply to yosoufe
    [deleted]
  • yosoufe
    yosoufe over 1 year ago in reply to anniel747
    controlling the speed of the car. This is a DonkeyCar-like project. https://www.donkeycar.com/
  • anniel747
    [deleted]
  • yosoufe
    No. It cannot. It has a DC motor. Not a BLDC.
