Member's Forum Machine learning and robotics
  • Replies 12 replies
  • Subscribers 628 subscribers
  • Views 2026 views
Oakleynick1
Oakleynick1 over 3 years ago
Hey everyone, I was wondering if Raspberry PI is a good way to go for starting my own projects in robotics. I'm in school for machine learning but I'm only scratching the surface as far as what my classes have to offer. Just need a little direction. Thanks.
  • yosoufe
    yosoufe over 3 years ago
    https://www.donkeycar.com/
    dougw over 3 years ago in reply to Oakleynick1
    Would a Huskylens do what you want?
    The Beaglebone Blue has more hardware interfaces which might reduce the amount of hardware you need to do your project. The Raspberry Pi may have more software available. It just depends where you prefer to spend your time and money.
  • Oakleynick1
    Oakleynick1 over 3 years ago in reply to robogary
    I'm kinda stuck between Tensor flow and Open CV, I don't have a lot of experience with them so something I can learn and grow with as well
  • Oakleynick1
    Oakleynick1 over 3 years ago in reply to colporteur
    I will look into it, thank you so much
  • colporteur
    colporteur over 3 years ago
    Being budget conscious maybe investing in a sensor kit will provide some hands-on experience you appear to be looking for.
    AN array of sensor allows you to develop some knowledge around the inputs and outputs of robotics.
    I have used a PiTop4 https://www.pi-top.com/bundles/robotics-electronics to help students get some physical experience. It is a pricey unit if you are on a student budget. An inexpensive sensor collection is much cheaper with the added benefit you have to do more of the heavy lifting in setting up scenarios. The PiTop4 is designed to remove most of that by connectorizing the setup.
  • robogary
    robogary over 3 years ago
    Raspberry Pi 4 can be used, others maybe better, depending on what your investment/budget plan is. Are you thinking to start with OpenCV , Tensor flow,  ROS2 ?
  • Oakleynick1
    This would be an automated photography project
  • Oakleynick1
    Adaptive learning like reacting certain ways to specific shapes and movement of objects while considering time of day as well.
  • colporteur
    colporteur over 3 years ago in reply to Oakleynick1
    What are you looking for in the term Learning Aspects?
