Member's Forum Optical Fibres
  • Subscribers 625 subscribers
  • Views 826 views
Optical Fibres
saikrishna27
saikrishna27 over 3 years ago
Hello everyone,
I recently discovered the intricacies involved in optical fiber splicing, particularly when it comes to repairing physical damage in underground cables. The process typically requires digging the ground to locate the damaged section, cutting it off, and then using a splicing machine to reconnect the fibers using an electrical arc.
One crucial aspect of splicing is the alignment of the connecting ends of the fibers. For optimal performance, the angle of the cut should be perfectly perpendicular to the fiber. If the cut is not precise or if the cables don't align correctly during splicing, it can result in energy loss and dispersion at the spliced joint. This can accumulate over time and lead to data loss, potentially causing disruptions in internet connectivity for various hosted links.
To address these challenges, I believe there is an opportunity to explore alternative technologies or approaches that can improve the precision and efficiency of fiber optic splicing. Are there any robotic systems, advanced machines, or other innovative solutions currently in use or under development that could enhance the splicing process? By incorporating cutting-edge technology, we may be able to reduce the need for manual labor, minimize data loss, and avoid repeated repairs.
I am reaching out to this knowledgeable community to gather insights and suggestions. If you are aware of any existing solutions or emerging technologies that could revolutionize the field of optical fiber splicing, I would greatly appreciate your input. Let's collaborate to make splicing faster, more accurate, and less prone to energy loss.
Thank you in advance for your valuable contributions!
    DAB over 3 years ago
    There is a lot of technology out there for cutting and splicing fiber optics.
    It depends upon the material, the wavelengths, size, and operating conditions.
    There is no one universal tool, so be aware that any solution you come up with might have a limited audience.
  • robogary
    robogary over 3 years ago
    GloFiber just ran all new buried fiber cables in my locality. The existing fiber cables in the neighborhood are owned by another communications/internet/cable TV provider. It was quite a sight to see the conduits get pushed thru underground to junction areas, then the fibers get fed thru, finally the splicing, and the coup de grace, a special truck at the main trunk junction box for verification and I'm sure S/N measurements to each access point and back to the main trunk lines.
    I actually worked on fiber optic connectors, interconnections, tooling, etc for AMP, Inc 45 years ago as an engineering intern. Fiber splicing depends on the fiber material type and the transmission modes.  I would expect revolutionizing the interconnection takes a specialized knowledge of that business and a insight to materials sciences.
    dougw over 3 years ago
    It is always possible to improve on existing technology, but it is going to take quite a big development, in this case, to compete with what has already been developed. Here are some examples:
    https://www.youtube.com/watch?v=ugbHYHgte7U
  • anniel747
    anniel747 over 3 years ago
    global-sei.com/.../
