Member's Forum Imported electronic downlighters and ongoing safety responsibility?
  • Replies 12 replies
  • Subscribers 588 subscribers
  • Views 1811 views
davebullockmbe
davebullockmbe over 2 years ago
Where do I find (and who do I speak to) to establish who's responsibility it is once an electronic item is obsolete but is still in thousands of homes and offices?
I was asked to repair an LED downlighter and driver which had developed an strange fault. My client has over 100 of these downlighters in his property and had seven (7) displaying the same fault.
The cost of total replacement would be very high and so he asked for my help.
I eventually established the fault (an aged 1M Ohm resistor) which when replaced returned the downlighter to normal operation.
However, in my testing to find the fault I carried out some 'load' testing and found that in certain overload conditions the switching FET became extremely hot and looked like it would lead to the destruction of the driver and possible fire?
Where do I find out what tests would have been carried out on this specific CE & SELV marked item?
Were tests required to be carried out at ALL levels of overload?
As this item has now been replaced with an updated version, I doubt the Chinese manufacturer (or well known UK lighting distributor) will be willing to engage in any conversation that may lead to liability!
This item may be recently become obsolete, but is still 'out there' in ceiling and roof spaces in it's thousands.
Who can I have an intelligent discussion with, as all the safety websites I have visited don't seem to have the correct resources or contacts.
Thanks in anticipation
Dave
    shabaz over 2 years ago +4
    Hi, The manufacturer and distributor are under zero obligation to supply a customer with the list of tests they carried out, unless it's part of a contract (and even then, you can't force them; it's…
    michaelkellett over 2 years ago in reply to davebullockmbe +2
    For what it's worth I think you should be open with your immediate client and share with him any information you might have. It's sometimes hard to give clients the bad news but much easier in the long…
  • davebullockmbe
    davebullockmbe over 2 years ago in reply to shabaz +2
    HI everyone, First of all a great big thank you for all your knowledgeable responses. Having taken your sagely advice I communicated my findings to my client who was somewhat concerned and subsequently…
  • davebullockmbe
    0 davebullockmbe over 2 years ago in reply to shabaz
    HI everyone,
    Having taken your sagely advice I communicated my findings to my client who was somewhat concerned and subsequently gave me permission to carry out a "destructive" test on his LED driver.
    Bearing in mind that when I discovered the issue the power FET became unbearably hot within 20 -30 seconds I had not ventured any further.
    So I set up the test again but this time with a thermocouple bead thermometer fixed to the surface of the FET and then commenced the test.
    Result
    The FET rapidly gained in temperature as before and then more slowly until it reached a stable temperature of 78 Degrees C.
    Relieved, I repeated the test with a slab of expanded polystyrene fixed over the surface of the entire pcb to 'more than' emulate the board being inside it's plastic housing.
    Running the test again I monitored the FET temperature and it only increased to 85 degrees C, so I assume the pcb and associated trackwork was serving as an efficient heatsink.
    So, I thank you all for directing me to persevere with my testing as it would seem I was becoming over cautious.
    Dave
  • phoenixcomm
    0 phoenixcomm over 2 years ago
     davebullockmbe for a cheap solution and to avoid the conversion with the deaf, and dumb, up the wattage of the resistor about 2x of the FET's max current. ~~ Cris H.
