Member's Forum Imported electronic downlighters and ongoing safety responsibility?
  • Replies 12 replies
  • Subscribers 622 subscribers
  • Views 2124 views
davebullockmbe
davebullockmbe over 2 years ago
Where do I find (and who do I speak to) to establish who's responsibility it is once an electronic item is obsolete but is still in thousands of homes and offices?
I was asked to repair an LED downlighter and driver which had developed an strange fault. My client has over 100 of these downlighters in his property and had seven (7) displaying the same fault.
The cost of total replacement would be very high and so he asked for my help.
I eventually established the fault (an aged 1M Ohm resistor) which when replaced returned the downlighter to normal operation.
However, in my testing to find the fault I carried out some 'load' testing and found that in certain overload conditions the switching FET became extremely hot and looked like it would lead to the destruction of the driver and possible fire?
Where do I find out what tests would have been carried out on this specific CE & SELV marked item?
Were tests required to be carried out at ALL levels of overload?
As this item has now been replaced with an updated version, I doubt the Chinese manufacturer (or well known UK lighting distributor) will be willing to engage in any conversation that may lead to liability!
This item may be recently become obsolete, but is still 'out there' in ceiling and roof spaces in it's thousands.
Who can I have an intelligent discussion with, as all the safety websites I have visited don't seem to have the correct resources or contacts.
Thanks in anticipation
Dave
  • phoenixcomm
    0 phoenixcomm over 2 years ago
     davebullockmbe for a cheap solution and to avoid the conversion with the deaf, and dumb, up the wattage of the resistor about 2x of the FET's max current. ~~ Cris H.
  • davebullockmbe
    0 davebullockmbe over 2 years ago in reply to shabaz
    HI everyone,
    First of all a great big thank you for all your knowledgeable responses.
    Having taken your sagely advice I communicated my findings to my client who was somewhat concerned and subsequently gave me permission to carry out a "destructive" test on his LED driver.
    Bearing in mind that when I discovered the issue the power FET became unbearably hot within 20 -30 seconds I had not ventured any further.
    So I set up the test again but this time with a thermocouple bead thermometer fixed to the surface of the FET and then commenced the test.
    Result
    The FET rapidly gained in temperature as before and then more slowly until it reached a stable temperature of 78 Degrees C.
    Relieved, I repeated the test with a slab of expanded polystyrene fixed over the surface of the entire pcb to 'more than' emulate the board being inside it's plastic housing.
    Running the test again I monitored the FET temperature and it only increased to 85 degrees C, so I assume the pcb and associated trackwork was serving as an efficient heatsink.
    So, I thank you all for directing me to persevere with my testing as it would seem I was becoming over cautious.
    Dave
    0 shabaz over 2 years ago in reply to davebullockmbe
    This is not a unique situation from the point of view that millions of homes have dodgy electrical products ranging from genuine products like Whirlpool appliances to fake Apple chargers etc. It's a surprise when consumer products are of high quality (and they still may have some flaws).
    Also, it might seem obvious to some that a heated FET condition may cause a dangerous fire, but this might not be the case, and it doesn't imply that standards were not met.
    There was a case where there was an oil leak from a ship, and sparks caused a fire. The company causing the oil leak was not responsible, because even though the average person (and even some engineers!) might believe that an oil leak could cause a fire, in actual fact it was not reasonable to expect a fire to occur at all. It's easy to leap to conclusions.
    If you think something is dangerous, you have to make your client aware of it, anything else is immoral. If it costs the client money to fix, so be it. I routinely swap out chargers for family members, because I don't trust what they purchase (obviously I don't charge them for that of course).
    0 michaelkellett over 2 years ago in reply to davebullockmbe
    For what it's worth I think you should be open with your immediate client and share with him any information you might have. It's sometimes hard to give clients the bad news but much easier in the long run to live with yourself if you do.
    I don't know enough about LED failure modes to comment re low Z failure modes.
  • davebullockmbe
    0 davebullockmbe over 2 years ago in reply to michaelkellett
    HI,
    Thanks for all your comments and advice.
    I was expecting that as Michaelkellet suggests that because (as far as we know) there is only a 'hypothetical risk' then no one would be interested.
    I have discovered that the obsoleting of the driver module has occurred because the manufacturer has revamped the design using a different driver controller IC which doesn't exhibit this potential dangerous overload situation. (I've subjected one to the same barrage of tests) The driver unit is supplied in the same casing as the original and is externally indistinguishable from the earlier model other than a modification to the part number.
    Of course one can hypothesize that this upgrade is a result of devastating failures or just the unavailability or the original driver IC.
    Hopefully the former but we will never know or possibly find out.
    Of course my worries may be totally unfounded. Do COB LEDs ever go low impedance (which could cause this overheating situation), or do they ALWAYS go either short, or open circuit?
    Was the item ever required to be tested under ALL load conditions? That's what I need to find out.
    Lighting experts please comment.
    Finally
    I have scripted a long report of all my findings to the UK lighting seller, asking these questions (as some of you suggest), I am waiting for their response.
    As they already informed me that the item is now obsolete I suspect they may be non-cooperative and hope that I just go away?
    Having worked in a medical electronics environment it was imperative that understood potential electrical risks to patients and test subjects.
    However dealing with domestic equipment and navigating the latest regulations (especially since Brexit) seems to be a minefield.
    I don't have the time to do this hence my turning to the Element 14 community for your thoughts and advice.
    It was never my intention to contemplate any legal challenge over my discovery but now the "Genie is out of the bottle" I am left in a moral dilemma.
    Do I just return the repaired driver modules to my client as if nothing happened, or, do I mention my findings frightening him for the safety of his young family?
    The UK supplier doesn't seem to have what I would call a 'technical' department that can understand their product to 'board level' so I wouldn't be surprised if they had just taken the Chinese manufacturers word that the item was safe.
    I have opened a 'Pandoras Box' and don't like what I see........
    Thanks once again for your thoughts, please keep them coming
    Dave
    You are referring to your opinion of a hypothetical risk - so no one "official" is going to be very interested.
    If you think it's important then at least give the importer/distributor the chance to the the decent thing and tell them about it.
    Trading Standards https://www.citizensadvice.org.uk/consumer/get-more-help/report-to-trading-standards/ are responsible for enforcing CE marking regulations for consumer products in the UK and may have some advice for this situation.
    The importer may belong to a trade organisation which might possibly take it up.
    Generally situations like this do not provoke any official reaction (like publicity or recalls etc) until an actual (and serious) incident occurs. Mere failure out of warranty is not enough.
    If you feel really concerned about then go public - name names and post some pictures - if you stick to facts it is perfectly legal to do so.
    But you really should contact the distributor first and see what they say.
  • anniel747
    0 anniel747 over 2 years ago in reply to shabaz
    You should read this: en.wikipedia.org/.../CE_marking
    The manufacturer and distributor are under zero obligation to supply a customer with the list of tests they carried out, unless it's part of a contract (and even then, you can't force them; it's a general principle of contract law, that the remedy is damages usually).
    If it's deployed in offices, then it was a B2B transaction, governed by the contract. Consumer legislation is out of the window, all bets are off, because it depends on the contract T+C's.
    If it's purchased by consumers, and it can be shown to have caused damage to consumer property (e.g. fire caused by it damaged the home) then the supplier is liable for damage caused by their product (note - you can't take it to ridiculous extremes, and you can't lump in anything deemed 'economic loss' - your "cost of total replacement" that you refer to, is likely to include a huge element of that, and normally that is not compensated for - unless it's written in a contract!). Consumers best course of action is to discuss with Trading Standards if a product is believed to be dangerous. Consumers of course could raise a claim in a court before or after damage (e.g. if they can show a product is dangerous even before a product causes damage) but if you don't have the damage to show for it, then you'd have to be extremely certain it is worth doing, because although the lawyer is going to certainly be compensated, the plaintiff might not win the case at all. By the way, just because one person (even an expert) or even a group of experts says something is dangerous doesn't mean in itself that a supplier or manufacturer was 'negligent'. It's quite subtle. You'd certainly need a lawyer if you're going that route, and if it were me, I'd say one would be lucky if they walked away with any award in that situation, if you imagine the costs involved to get that far.
    0 dougw over 2 years ago
    Downlighters? - Is that like pot lights?
    0 Jan Cumps over 2 years ago in reply to kmikemoo
    UK is no longer in the European Commission. Very likely the OP will have to contact the national customer product safety department.
