Member's Forum ATX Power supply shopping, any tips?
  • Replies 18 replies
  • Subscribers 626 subscribers
  • Views 3249 views
  • atx psu
  • atx power supply
  • psu
  • thermaltake
  • atx
scottiebabe
scottiebabe over 2 years ago
I think its time to retire my Thermaltake Toughpower 650W ATX power supply.
Using the 80 plus test database seems like a good start
https://www.clearesult.com/80plus/manufacturers/115V-Internal?page=7
Fingers crossed LTT starts publishing PSU reviews with that test setup, just wow....
A random interview with a PSU designer:
  • anniel747
    anniel747 over 2 years ago in reply to scottiebabe
    BOM can change over time.
  • scottiebabe
    Thanks for all the helpful advise, in the end I went for a middle of the road PSU
    The "Corsair RMe Series RM750e Fully Modular 80PLUS Gold ATX 3.0 & PCIe 5.0 Compliant Power Supply"
    When I receive the unit, I'll post some photos.
    Another review site that I discovered after the fact is: https://www.cybenetics.com/index.php?option=power-supplies
    They even provide component breakdowns
    https://www.cybenetics.com/d/cybenetics_XWx.pdf
    Hurray for Teapo!
  • JWx
    JWx over 2 years ago in reply to JWx
    for example: upgrade from this 300W PSU
    300W PSU
    to this 500W PSU
    500W PSU
    can be a downgrade depending on load parameters...
  • JWx
    I have observed that ATX supplies parameters have changed sometime in the past - old ones provide most of the power on 3.3V/5V rails, but modern ones on 12V - to the level that 500W modern PSU cannot power PC of old (several years ago, for some tests we have been building PC with power-hungry GPU, but using existing [old] hardware - and the PC was not able to power up using a brand-new PSU. We had to use dual PSU configuration - old one was powering motherboard and a new one was used as an auxiliary power for the GPU)
    So - if the machine is very old, not only power but power distribution between voltages is to be checked
  • cstanton
    cstanton over 2 years ago
    I'm running MSI's MEG Ai1300P.
    It's quiet and has direct fan control while handling whatever I throw at it. It may be overkill for your needs.
    I used to have a Corsair CX850M running an Intel i7 and GeForce 3080, and it wasn't meant to Smiley I kept browning out when pulling too much power at once on the rails even though it technically should have been able to handle it.
  • anniel747
    anniel747 over 2 years ago in reply to baldengineer
    Wires are copper not CCA like many others.
  • baldengineer
    baldengineer over 2 years ago in reply to anniel747
    I'll +1 on Corsair supplies. I used them in three builds (two with 400W and one with 850W.) The modular cables are good build quality, they include a usable assortment, and their Windows software is actually decent. On my editing machine, I use the software to force the fan on high when I render or do GPU-intensive stuff.
    I've never bothered to hook it up to an oscilloscope, but I have no reason to suspect any issues.
  • Gough Lui
    Gough Lui over 2 years ago in reply to anniel747
    Well, I'll get around to replacing it one day. But since I use it rarely, I'll hang on for a little longer.
  • obones
    obones over 2 years ago in reply to anniel747
    Woops, typing too fast here, you are definitely right, I edited my original reply
  • anniel747
    anniel747 over 2 years ago in reply to Gough Lui
    Careful with the badcaps, it's a good way to kill your hard drive. In the PS as on MB.
