Ask an Expert Forum AIS Transponder
  • Replies 9 replies
  • Subscribers 323 subscribers
  • Views 2630 views
See a helpful answer?
AIS Transponder
tohimjob
tohimjob over 2 years ago
I need to know how to make an Automatic Identification systems transponder that sends and receives proximity warnings from other vessels in the vicinity but does not report time and location to an open database like the one that Elon Musk could shut down only because he owned the platform, when someone was giving the location of his private Jet in realtime on twitter.
  • robogary
    robogary over 2 years ago +2
    Must be big time if worried about Elon Musk.
  • beacon_dave
    beacon_dave over 2 years ago +1
    That might be difficult as any nearby vessel receiving your AIS transponder signal could forward the time and location data to an open database, which could then be used to report to an on-line platform…
  • anniel747
    anniel747 over 2 years ago in reply to beacon_dave +1
    Deleted
  • robogary
  • beacon_dave
    That might be difficult as any nearby vessel receiving your AIS transponder signal could forward the time and location data to an open database, which could then be used to report to an on-line platform.
  • anniel747
    [deleted]
  • beacon_dave
    beacon_dave over 2 years ago in reply to anniel747
    True, but the original message suggested send and receive though:
    If everyone only receives then I can see a bit of a problem with this setup.
  • anniel747
    [deleted]
  • JWx
    JWx over 2 years ago
    I don't know how exactly one can send proximity warnings to other vessels without revealing one's position... "There is something in the range of radio transmission, but we don't know where (may be in front or at the left for example) or how far away - maybe 200 km from us? Signal is somewhat weak - but they may be nearby and have damaged antenna ..."
    EDIT: technically, there is a possibility to omit time/position data that should be transmitted in the AIS message by using "no available" values, but that would be useless and maybe illegal - radio propagation changes so what's a point of having information "I can hear something, but I don't know where and how far from my position". And about "open database" - AFAIK databases are feed by network of independent receivers listening to all the messages - the same way as plane positions are recorded, not by AIS devices themselves, and crews wanting to avoid letting their position known (for example to hide their illegal activity, like sanctions avoidance or illegal fishing) are powering off their AIS altogether
    https://en.wikipedia.org/wiki/Automatic_identification_system
  • beacon_dave
    You mean like sending your position along with multiple fake positions, such that you will hopefully be avoided but no-one knows which position is actually you ?
  • axios_ftw_0187
    axios_ftw_0187 over 2 years ago
    The hack rf one parta packs can do some amazing things
  • phoenixcomm
    phoenixcomm over 2 years ago
     tohimjob is this a typo or did you mean TACAS? (aircraft)? AIS I don't have.  ~~ Cris
