Member's Forum why jumpstarter and not a cable boost
  • Replies 18 replies
  • Subscribers 591 subscribers
  • Views 1601 views
  • boost converter
  • battery
colporteur
colporteur over 1 year ago
I tried jump starting my aunts car and failed. What did start the care was my cousins nektech jumpstart device. Why one and not the other?
I'm on vacation so test equipment is in short supply. The dead car wouldn't even provide dash lights when connected to boost vehicle. I figured it should have started on cable boost or at least get lights. I'm thinking ratty booster cables.
It seems reasonable a cable boost or jumpstart work the same way. Curious minds want to know.
  • colporteur
    colporteur over 1 year ago +4
    I had to go back and try to determine why it didn't work. The picture is the connections of the four ends of the jumper cables. The cable is robust but the insulation wasn't stripped away before they were…
    shabaz over 1 year ago +3
    Hi! I think you're right, probably poor-quality jumper cables. Some have thin copper but thick insulation, and others have their wire ends folded over the insulation, and then a single crimp around the…
  • robogary
    robogary over 1 year ago +3
    maybe a bad clip connection to the battery post in the first try
  • ntewinkel
    ntewinkel over 1 year ago in reply to shabaz
    safety first! Laughing
  • Christopher678
    Christopher678 over 1 year ago
    I like it to
  • md_steve
    md_steve over 1 year ago in reply to anniel747
    Did you mean to say 'cost reduction'?
  • kmikemoo
    kmikemoo over 1 year ago in reply to colporteur
    That's impressive.  It takes skill to mess up to that level.  At least they were consistent.
  • robogary
    robogary over 1 year ago in reply to colporteur
    Quality is job 1 :-)
  • beacon_dave
    beacon_dave over 1 year ago in reply to colporteur
    Looks like a hot melt insulation strip process failed to complete before the crimping took place.
    I'm guessing this would be a blast of hot air, so any change in the insulation material would need a thermostat or timer to be adjusted.
  • anniel747
    anniel747 over 1 year ago in reply to beacon_dave
    [deleted]
    Jan Cumps over 1 year ago in reply to anniel747
    I think you have it correct. Contact resistance and high current cause symptoms like these.
