Member's Forum why jumpstarter and not a cable boost
  • Replies 18 replies
  • Subscribers 623 subscribers
  • Views 2325 views
  • boost converter
  • battery
colporteur
colporteur over 2 years ago
I tried jump starting my aunts car and failed. What did start the care was my cousins nektech jumpstart device. Why one and not the other?
I'm on vacation so test equipment is in short supply. The dead car wouldn't even provide dash lights when connected to boost vehicle. I figured it should have started on cable boost or at least get lights. I'm thinking ratty booster cables.
It seems reasonable a cable boost or jumpstart work the same way. Curious minds want to know.
    Jan Cumps over 2 years ago in reply to anniel747
    I think you have it correct. Contact resistance and high current cause symptoms like these.
  • anniel747
    anniel747 over 2 years ago in reply to beacon_dave
    [deleted]
  • beacon_dave
    beacon_dave over 2 years ago in reply to colporteur
    Looks like a hot melt insulation strip process failed to complete before the crimping took place.
    I'm guessing this would be a blast of hot air, so any change in the insulation material would need a thermostat or timer to be adjusted.
  • robogary
    robogary over 2 years ago in reply to colporteur
    Quality is job 1 :-)
  • kmikemoo
    kmikemoo over 2 years ago in reply to colporteur
    That's impressive.  It takes skill to mess up to that level.  At least they were consistent.
  • md_steve
    md_steve over 2 years ago in reply to anniel747
    Did you mean to say 'cost reduction'?
  • Christopher678
    Christopher678 over 2 years ago
    I like it to
  • ntewinkel
    ntewinkel over 2 years ago in reply to shabaz
    safety first! Laughing
    shabaz over 2 years ago in reply to colporteur
    At least no danger when connecting those the wrong way : )
    That should win an award for worst assembly ever : ) I'd half expected the wire to at least be folded over the insulation (that was the previous worst I'd seen).
  • ntewinkel
    ntewinkel over 2 years ago in reply to colporteur
    To quote the MythBusters: "Well theeeere's yer problem!"
    I like those little jumpstart boxes. They seem to work well and take up very little space - less space than jumper cables.
    i've also used one to power 12v LED lighting in a little camper, and also to test trailer lights (the father-in-law's boat trailer in salty water has failed a lot!).
    It looks like you'd have to unclamp the jumper cable ends, strip the insulation, and then solder and crimp reassemble it all. I think some of the crimps do go over the insulation, but you would need the inner wire to make contact somewhere Slight smile  You might need a little propane torch like when you're soldering plumbing pipes.
    I'd be tempted to just buy a jumpstarter instead... but then again, those cables have made it personal and require an attitude adjustment to show them who's boss! Laughing
