Member's Forum Source for 5-pin "dice" style DIN plugs?
  • Replies 10 replies
  • Subscribers 625 subscribers
  • Views 1375 views
  • connectors
  • serial port
  • retro
Danj
Danj over 2 years ago
Does anyone know where I can find a 5-pin DIN plug with the pins in a "dice" or "domino" configuration? Non-locking as it will be connecting to a panel mounted socket. Type of signal is serial port, I actually need to make up a cable with one of these and a DB9 on the other end, for use with a retro computer (BBC Micro).
Seems like these types of connectors are rare these days and I've been having trouble finding one.
  • phoenixcomm
    0 phoenixcomm over 2 years ago in reply to electronicbiker
      electronicbiker A long time ago I had a PC (game port-to-USB adapter, for my first stick, which days chained to my stick and throttles. Thank you SunCom!!! ~~ Cris h.
    pm. see NexGen: Hacking the Dual Throttle Quadrant.
  • electronicbiker
    0 electronicbiker over 2 years ago in reply to beacon_dave
    You are absolutely right - I wasn't happy with 'RS484' when I replied, something was nagging at my brain but it was getting late so I decided to ignore it. Or, it could be long covid or the effects of the jabs that are supposed to be preventing me from getting it.
    Originally a Model A I soon fitted the extra RAM to enable Model B software to run, and allow the extra screen modes to be used, then I fitted the diode around the cassette on/off relay, the extra ROM sockets soon got used up, the speech chips were added (I could then call a friend of mine with 'CQ G4xxx' without having to do it myself) and found that the Beeb would follow Morse Code up to 25wpm with a simple BASIC program that auto-tracked the speed, and I could transmit using the keyboard instead of a key, marvellous days...  Then came one 40-track single sided disk drive, improving as time went on up to a pair of 80-track double-sided. A Watford Electronics ROM expander board arrived, and by this time a fan became necessary. Later, with an A5000, I still have a 'JoyMouse' converter allowing a joystick to be used instead of the mouse, how on earth anyone can fly an aeroplane with a mouse I do not know. JoyMouse had an early PIC chip in it, the one with four A-D converters on board.
  • beacon_dave
    0 beacon_dave over 2 years ago in reply to electronicbiker
    electronicbiker said:
    I always remember the RS484 port as a 'domino' from happy days with a BBC Micro
    If I recall correctly, the BBC Micro used RS-423 for serial.
  • electronicbiker
    Yes, those are the ones! Thanks beacon_dave, I'll get a couple in before they dry up altogether.
    I always remember the RS484 port as a 'domino' from happy days with a BBC Micro, a packet radio TNC, a crystal-controlled Yaesu 2-metre walkie-talkie, and, of course, a Class A licence to keep it legal, probably mid-80's.
  • beacon_dave
    CPC still refer to it as 'domino'.
    does anyone know where to get a 5-pin in-line DIN plug
    Do you mean these ?
    https://www.youtube.com/watch?v=DoG1UH81PAw
    https://philipsag9015.home.blog/2019/08/13/connectors/
  • anniel747
    0 anniel747 over 2 years ago in reply to colporteur
    DIN; in English, is the German Institute for Standardisation and has many standards.
  • colporteur
    0 colporteur over 2 years ago in reply to beacon_dave
    It looks like DIN connector has different meanings. Nothing like a picture to understand that your DIN and my DIN are the same.
  • electronicbiker
    0 electronicbiker over 2 years ago in reply to electronicbiker
    Wow! They've changed from 'Domino' to 'Dice'! When did that happen? Talking of oddball DIN plugs, does anyone know where to get a 5-pin in-line DIN plug? Used on old Philips tape recorders as a high-impedence input for crystal record-player cartridges, the pins were rectangular with one turned 90 degrees to provide orientation when plugging-in.
  • electronicbiker
    Actually known as 'domino' plugs, available from CPC and Farnell, several sleeve types and colours, average a fiver each.
  • beacon_dave
    CPC still do them
    https://cpc.farnell.com/deltron-enclosures/611-0520/5-pin-domino-black-din-plug/dp/CN00054
    Buy Now
