Member's Forum E220-Remote-Switch using Wake on Radio (WOR) to wake Deep Sleeping ESP32.
  • Subscribers 625 subscribers
  • Views 727 views
  • esp32
  • video
  • microcontrollers
ab9nq
ab9nq over 2 years ago
Introduction:
Goal:  Conserve battery power for a Wyse Cam3 video camera that has a current draw 180 mA at 5 volts.  Camera viewing is web based and has a very low demand to view camera; less than five views per day.  Using a remote switch controlled by Async Web Server request will prevent battery draining power twenty-four hours a day.  Currently a 10,000-mA battery bank only lasts a day.
Overview of the Project:
E220 Remote Switch project will reduce battery consumption by utilizing a countdown timer; started upon web request, turned off, on countdown timer expiration.  When web request is severed the E220-900T30D Sender module will send a wake-on-radio (WOR) message. Receiver E220 module wakens from the Sleep Mode.  Sleep Mode is an ultra-low current state in the microamp range.  ESP32 will wake from Deep Sleep and turn on battery power; at the same time the E220 module receives the WOR message.  When countdown timer has expired; E220 Sener module will send a message, switching battery power off and putting the ESP32 into deep sleep and put the receiving E220 module into sleep mode.  Cycle repeats on new web request.
E220-Remote-Switch project has been updated  to include E220 Sleep Mode; reducing always on current comsumption to microamp range!
E220-Remote-Switch Project Code 2
Best Regards,
William
  • ab9nq
    Found an issue with the KY002S Bi-Stable Switch; whenever ESP32 Reset button was pushed, the KY002S would toggle states.
    Updated 07/29/2024: E220-Remote-Switch project now includes KY002S Bi-Stable MOSFET Switch and the INA226
    Battery Monitor with under voltage alert.
    Implementing E220 Remote Switch.pdf
