Member's Forum Air Band Receiver High Sensitivity Aviation Radio 118-136MHz AM DIY Kit
  • Replies 18 replies
  • Subscribers 591 subscribers
  • Views 5849 views
scottiebabe
scottiebabe over 1 year ago
A 30 year-old electronics hobby kit still lives on to this day.
I came across a superhet airband receiver kit that peaked my interests. It’s based on a few venerable but not extinct radio ICs, namely the NE602 and the MC1350. I don’t know where the kit producer is sourcing these ICs, but for $20 it was worth taking a chance on it being more than a pack a of bubblegum. Fingers crossed I receive at least functional equivalent ICs, if not new/salvaged old stock.
You can find the kit at the usual places searching “Air Band Receiver High Sensitivity Aviation Radio 118-136MHz AM DIY Kit”
The schematic is to clean and logical to be a typical noname solder kit. After some digging around on the internet, I found the origin of the kit. This project was originally designed by Fred Blechman and published in the spring 1994 issue of "Electronics Hobbyist Handbook" by Gernsback Publications.
A pdf of the publication is available here:
https://www.worldradiohistory.com/Archive-Poptronics/Experimenters-Handbook/Electronic-Hobbyist-Handbook-1994-Spring.pdf (Page 82)
Tony van Roon also shares their experience and analysis of the project kit here:
https://www.learningelectronics.net/VA3AVR/circ/aviarx/aviarx.html
  • Mattia.Zamana
    Mattia.Zamana 8 months ago +5
    This ️ is how I made it. I'm really happy with the aesthetic result and the receiver works really well. https://youtu.be/s0W8N2rxZcE?si=ZyAJDXZWBiyXQrJD
    dougw over 1 year ago +3
    Looks like a nice through hole project. The sockets will help if there are problems with the ICs.
  • kmikemoo
    kmikemoo over 1 year ago +3
    scottiebabe Nice find. Like many cool thing... not new, but new again. So far, I've resisted buying one. I look forward to your "review".
  • scottiebabe
    scottiebabe over 1 year ago in reply to colporteur
    In this case the designer didn't capture the PCB inductor as circuit component and just "winged" it with PCB traces.
    How PCB artwork is drawn at a schematic level isn't quite as rigidly defined. Here's an LNB example
    https://www.nxp.com/docs/en/application-note/AN11674.pdf
    DAB over 1 year ago
    Looks like you can have some fun with it.
  • scottiebabe
    The front-end preselect filter is OK, it has some insertion loss and not a whole lot of rejection in the FM broadcast band. Could it be better, possibly, but it's not a showstopper.
    The local oscillator created with the NE602 is alive and well.
    The tuning potentiometer varactor tunes the LO from 130.7MHZ to 145 MHz (left my SA in max hold while twiddling the tuning pot)
    So far it would appear as though I got a real NE602 Slight smile
    Jan Cumps over 1 year ago in reply to scottiebabe
    Did you have your tongue in the right angle?
  • scottiebabe
    scottiebabe over 1 year ago in reply to Jan Cumps
    LOL dave is the best! Adjusting a one-turn pot to 0.1% of its full scale range will require some tongue work...
    If the rxcv has 10 kHz IF bandwidth and 14 MHz tuning range.
  • nobcha
    nobcha over 1 year ago in reply to scottiebabe
    Hi, I have ever assembled these kits. It's cheap but very nice, when you improve some.PCB inductors are bad.
    Please refer my report of "I studied how to tune PCB pattern type filter".
    nobcha23.hatenadiary.com/.../174051
  • dan.corneanu
    dan.corneanu over 1 year ago in reply to scottiebabe
    Hey,
    I've just received mine and I think that the NE602 is faulty because it does not oscillate.
    It's obvious it has been harvested from another board and it has some signs of abuse.
    However, before I throw away the IC and try to source another one, any suggestions on how I could prove that the IC is indeed the culprit?
    Dan
  • Mattia.Zamana
    This Arrow double down️ is how I made it. I'm really happy with the aesthetic result and the receiver works really well.
    • Vote Up +5 Vote Down
