Member's Forum How to get "free" stuff on element 14
  • Replies 30 replies
  • Subscribers 592 subscribers
  • Views 3132 views
  • free stuff
dougw
dougw over 1 year ago
There are lots of ways to get "free" stuff on element14, although none of them are free of effort and none of them are guaranteed to work. Here is a little explanation of the ways I am familiar with to get free stuff on element14 along with the typical strings attached:
  1. Periodically there are promotional "free" giveaways of new products. These are easy to apply for, but you need to be a member and you need to write an application. Sometimes the application requires you to specify why you want the product or what you would use it for. Sometimes you need to provide a bit more justification of why you need the product - like a mini proposal. Generally, these promotions operate like a lottery and the less work that is required to write the application the less likely you are to win. And of course the more popular the product is the less likely you are to win. Sometimes there are eligibility criteria such as you have to be a teacher and use the product for educational purposes or you may need to consent to use of your material in promotional activities.
  2. Sometimes there are free giveaways of swag or even products to members who participate on the forum. This is more likely to happen to you if you participate more actively. If you participate enough to become a top member, it happens even more. This isn't a predictable thing, but it is great when it happens.
  3. Sometimes there will be a mini contest with an associated giveaway. It could be as simple as explaining what you would use a particular product for, or answering questions in a quiz correctly, or identifying some obscure picture. Sometimes the quiz has general technical questions, and sometimes they are related to the sponsor of the giveaway. Sometimes there is a choice of products to win in these contests.
  4. Sometimes there is a contest associated with a particular product, company or event that has a product or swag as a prize. For example the may be a contest for Arduino Day, or Pi Day or May 4th. The difficulty of winning is usually proportional to how desirable the prize is or how much it is worth. Sometime the prizes are quite expensive and sometimes they are just swag.
  5. Usually there are project contests associated with specific holidays or celebrations, such as Halloween or Christmas. These are usually run like Project14 and require you to build a project that wins over competing projects, where the project theme is related to the particular event.. There may be specific products as prizes or there may be discretionary shopping cart prizes.
  6. The prizes for Project14 contests are usually discretionary shopping carts. The themes for Project 14 contests are chosen member votes and judged by volunteer members. This is one of the higher probability methods of winning free stuff, but it does take some work. These Project14 contests have the most freedom to use whatever components the designer wishes and come with very few strings, including no obligations to even complete the project.
  7. Road test equipment is routinely offered to members in exchange for publishing a blog about the road test experience. The difficulty in winning one of these is that you have to write a road test proposal that is more compelling than competing proposals, and you have to demonstrate credibility regarding completion of the road test. (Such as having previously published blogs)
  8. Design challenges are bigger projects that can offer larger prizes, but may involve much more work. They involve incorporating some kit supplied by a sponsor in a project and creating multiple blogs. First you have to win the kit by generating a winning application (project idea/proposal), then you have to complete the project and write a bunch of blogs that are better than competitor blogs, The kit can also be quite expensive in some cases.
  9. If you want to participate in more defined project compensation, you can become a publisher on Element14 Presents. You need to sign up for the program and generate proposals that includes costs and compensation. Once the proposal is accepted, you have a contract with known compensation and supplied kit.
  10. Webinars on the forum may provide draw prizes to attendees.
For those who put in the effort, there is a lot of potential free stuff to be had. There is usually a learning curve to figure out how much effort is required to win each type of contest, but a lot can be learned by looking at how previous contest entries worked. The winning probability will increase as you gain experience and credibility. It also pays off to check the site regularly for give-away activity. Generally it is not a way to make a good wage, but it is a great way to partially defray costs while having fun making things, learning about technology, acquiring skills, and learning how to create good proposals and interesting blogs.
All these methods of obtaining free stuff add to the fun and help to make this the best forum on the net.
I have certainly benefitted enormously from these programs, including outfitting my lab with a pretty complete suite of instrumentation that I would not otherwise have been able to afford.
How have you benefitted from these programs and have I missed any methods?
  • cstanton
    cstanton over 1 year ago +6
    Ah, so many ways to get free stuff. I must say, that none of the competitions or giveaways are a lottery. They all have to have some element of being a game of skill, and a decision ultimately has to…
  • battlecoder
    battlecoder over 1 year ago +3
    Thanks for such a thorough list. I've only participated of one Roadtest so far, and I had a blast. I had applied to other RTs in the past, to be fair, but I wasn't as active as I am now (actually I wasn…
    DAB over 1 year ago +3
    Free is a relative term. I have received my fair share of interesting things from element14, but I have also spent a lot of time reviewing projects, posting comments and providing help those in need…
  • cstanton
    I must say, that none of the competitions or giveaways are a lottery. They all have to have some element of being a game of skill, and a decision ultimately has to be made by a Community staff member with the final say.
    Random acts of kindness unrelated to competitions are also sometimes something the team does, which I find nice.
    • Vote Up +6 Vote Down
  • scottiebabe
    scottiebabe over 1 year ago
    Might be a FREE lights show in the sky tonight.
    Jan Cumps over 1 year ago in reply to scottiebabe
    Photos or it didn't happen
    dougw over 1 year ago in reply to scottiebabe
    Nada so far....still overcast
  • ralphjy
    ralphjy over 1 year ago
    As I put on my Ben Heck Show t-shirt this evening it occurred to me that some of the most useful (and used) free items that I've gotten from E14 have been the t-shirts.  I don't even recall why I have so many.  I even gifted a couple to my older son who is also an EE.  Hackster, another Avnet community, has also been a good source of t-shirts but mainly manufacturer branded (Xilinx, Nordic, Intel, etc.).
    I really loved the Ben Heck Show...
    shabaz over 1 year ago in reply to ralphjy
    BH Show was great.
    I have a really smart-looking black umbrella with big Intel logo. It has a really interesting button-operated opening _and_ closing feature. Good quality, I've had it for maybe 8 years. It rains a lot, I make good use of it!
  • scottiebabe
    scottiebabe over 1 year ago in reply to Jan Cumps
    Looked out at midnight and 2am, didn't see it. Reports online show it happened but can't confirm.
    dougw over 1 year ago in reply to ralphjy
    I use the T shirts a lot as well. I also use the metal flask every day. I sometimes use e14 breadboards, back packs, ball caps, and pens. Swag I use from other companies include PCB coasters, pop can cozies, mouse pads, PCB rulers, mugs, bottle openers, hockey pucks, and a nice Wurth phone stand.
    DAB over 1 year ago
    I have received my fair share of interesting things from element14, but I have also spent a lot of time reviewing projects, posting comments and providing help those in need.
    So I consider everything I have gotten as a return for my time and knowledge.
    I have greatly enjoyed interacting with everyone in the community and I have made lots of friends around the world.
    As the old saying goes, you get something out of a community depending upon how much time and effort you put into the community.
  • Andrew J
    Andrew J over 1 year ago in reply to scottiebabe
    You all do realise the Northern Lights are photoshopped right? Have you noticed only other people see them Wink
