Member's Forum How to get "free" stuff on element 14
  • Replies 30 replies
  • Subscribers 592 subscribers
  • Views 3133 views
  • free stuff
dougw
dougw over 1 year ago
There are lots of ways to get "free" stuff on element14, although none of them are free of effort and none of them are guaranteed to work. Here is a little explanation of the ways I am familiar with to get free stuff on element14 along with the typical strings attached:
  1. Periodically there are promotional "free" giveaways of new products. These are easy to apply for, but you need to be a member and you need to write an application. Sometimes the application requires you to specify why you want the product or what you would use it for. Sometimes you need to provide a bit more justification of why you need the product - like a mini proposal. Generally, these promotions operate like a lottery and the less work that is required to write the application the less likely you are to win. And of course the more popular the product is the less likely you are to win. Sometimes there are eligibility criteria such as you have to be a teacher and use the product for educational purposes or you may need to consent to use of your material in promotional activities.
  2. Sometimes there are free giveaways of swag or even products to members who participate on the forum. This is more likely to happen to you if you participate more actively. If you participate enough to become a top member, it happens even more. This isn't a predictable thing, but it is great when it happens.
  3. Sometimes there will be a mini contest with an associated giveaway. It could be as simple as explaining what you would use a particular product for, or answering questions in a quiz correctly, or identifying some obscure picture. Sometimes the quiz has general technical questions, and sometimes they are related to the sponsor of the giveaway. Sometimes there is a choice of products to win in these contests.
  4. Sometimes there is a contest associated with a particular product, company or event that has a product or swag as a prize. For example the may be a contest for Arduino Day, or Pi Day or May 4th. The difficulty of winning is usually proportional to how desirable the prize is or how much it is worth. Sometime the prizes are quite expensive and sometimes they are just swag.
  5. Usually there are project contests associated with specific holidays or celebrations, such as Halloween or Christmas. These are usually run like Project14 and require you to build a project that wins over competing projects, where the project theme is related to the particular event.. There may be specific products as prizes or there may be discretionary shopping cart prizes.
  6. The prizes for Project14 contests are usually discretionary shopping carts. The themes for Project 14 contests are chosen member votes and judged by volunteer members. This is one of the higher probability methods of winning free stuff, but it does take some work. These Project14 contests have the most freedom to use whatever components the designer wishes and come with very few strings, including no obligations to even complete the project.
  7. Road test equipment is routinely offered to members in exchange for publishing a blog about the road test experience. The difficulty in winning one of these is that you have to write a road test proposal that is more compelling than competing proposals, and you have to demonstrate credibility regarding completion of the road test. (Such as having previously published blogs)
  8. Design challenges are bigger projects that can offer larger prizes, but may involve much more work. They involve incorporating some kit supplied by a sponsor in a project and creating multiple blogs. First you have to win the kit by generating a winning application (project idea/proposal), then you have to complete the project and write a bunch of blogs that are better than competitor blogs, The kit can also be quite expensive in some cases.
  9. If you want to participate in more defined project compensation, you can become a publisher on Element14 Presents. You need to sign up for the program and generate proposals that includes costs and compensation. Once the proposal is accepted, you have a contract with known compensation and supplied kit.
  10. Webinars on the forum may provide draw prizes to attendees.
For those who put in the effort, there is a lot of potential free stuff to be had. There is usually a learning curve to figure out how much effort is required to win each type of contest, but a lot can be learned by looking at how previous contest entries worked. The winning probability will increase as you gain experience and credibility. It also pays off to check the site regularly for give-away activity. Generally it is not a way to make a good wage, but it is a great way to partially defray costs while having fun making things, learning about technology, acquiring skills, and learning how to create good proposals and interesting blogs.
All these methods of obtaining free stuff add to the fun and help to make this the best forum on the net.
I have certainly benefitted enormously from these programs, including outfitting my lab with a pretty complete suite of instrumentation that I would not otherwise have been able to afford.
How have you benefitted from these programs and have I missed any methods?
  • cstanton
    cstanton over 1 year ago +6
    Ah, so many ways to get free stuff. I must say, that none of the competitions or giveaways are a lottery. They all have to have some element of being a game of skill, and a decision ultimately has to…
  • battlecoder
    battlecoder over 1 year ago +3
    Thanks for such a thorough list. I've only participated of one Roadtest so far, and I had a blast. I had applied to other RTs in the past, to be fair, but I wasn't as active as I am now (actually I wasn…
    DAB over 1 year ago +3
    Free is a relative term. I have received my fair share of interesting things from element14, but I have also spent a lot of time reviewing projects, posting comments and providing help those in need…
  • scottiebabe
    scottiebabe over 1 year ago in reply to Andrew J
    Could be. Sounds like I need a DIY solar wind generator for the garden.
    Jan Cumps over 1 year ago in reply to scottiebabe
    I asked AI to add polar light to a photo of my house
    As is
    To be
  • scottiebabe
    scottiebabe over 1 year ago in reply to Jan Cumps
    DAB over 1 year ago in reply to scottiebabe
    They did not make if far enough south for my cameras to pick up anything.
    dougw over 1 year ago in reply to DAB
    When I receive "free" stuff, I look at it as a team reward. If the whole team wasn't participating, the give away wouldn't even happen.
    Presumably the objectives of "free" (skill testing) give aways are to generate good will, increase exposure and attract members.
    We demonstrate how well these objectives are met by positive participation, so increased member participation would seem to be the best way to encourage more (skill testing) give aways. When we receive "free" stuff it is important to demonstrate that it is having the desired effect with regard to the objectives - ie. blog about it.
    The whole process is a team effort, which is another good reason for us to provide positive encouragement to members and increase their enjoyment factor.
    Everybody wins.
    You are one of the major positive forces on the forum and it makes a difference. If there were more members that do what you do, it would do astounding things to the forum.
  • cstanton
    cstanton over 1 year ago in reply to DAB
    DAB said:
    So I consider everything I have gotten as a return for my time and knowledge.
    It's an interesting consideration to make.
    It's also one that I bring up with the team whenever we plan or arrange to do a competition for the Community.
    Some consider it a sensitive topic, and bringing it up can often unintentionally cause harm because most people do not think about it this way, but the introduction of websites such as Patreon, conflicts in the 'open source movement' and what I would say an "abuse of goodwill" has caused a lot of backlash of what is asked for in return for winning a "prize".
    In particular, I would point out that what goes on in the back of my mind is the "f-- you, pay me" presentation.
    When there is an imbalance between the effort put in, for the reward given, then there's a significant problem and we should always make sure that the reward is worth the effort and perceived effort.
    dougw over 1 year ago in reply to cstanton
    Although monetary value is nice and is a universal motivator, rewards for me are separately equated to the effort involved. For example winning a major design challenge means a lot more than winning a quiz, because there is a lot more effort involved. The prize for winning is an indicator or token of the achievement and its value is like the value of an Olympic medal - much higher than its monetary value. It is nice that the prize monetary value is generally higher for contests that require more effort, but they won't be on the same scale as work wages.
    Incidentally, winning a big design challenge can require as much training, experience and effort as winning an athletic medal...Relaxed
    I do enter some contests because the prize is nice, but if the monetary value was the only reason, it would almost never be worth entering. Most contest entries don't even win anything of monetary value.
    Jan Cumps over 1 year ago in reply to cstanton
    Part of that reward is the "joy of playing with electronics, do some engineering". And the "you of sharing the experience" part of writing blog posts. Hard to quantify, but in my case it's the biggest driver.
    I used this at work maybe an hour after you posted it. Pay forward Slight smile
  • inavitech
    inavitech over 1 year ago in reply to scottiebabe
    My friend who lives in MI said he was able to get a real nice pic of the Northern lights and sent it to me.
