Member's Forum I had a feeling portable mini-fridges were near useless
  • Replies 8 replies
  • Subscribers 624 subscribers
  • Views 1654 views
  • peltier cooler
  • mini fridge
stanto
stanto over 2 years ago
I bought one from B&M not long ago, and threw temperature sensors into it, and it couldn't maintain temperature, took ages to get to a low temperature, and it didn't reach the temperatures it claimed on the box. It claimed it could reach so many degrees less than ambient, it didn't.
I found this youtube channel, and it is pretty cool:
They pretty much come to the same conclusions I did, and then compare against "actual" fridges.
Mainly USA centric though.
  • James123
    James123 over 2 years ago
    This is something that would go on my "I wouldn't buy it even if I had the money" list.
  • stanto
    stanto over 2 years ago in reply to battlecoder
    battlecoder said:
    I wonder if you could "improve" on that regard if you added a thermoucouple and a low-power micro that would turn the Peltier element OFF when it reaches a target temperature and ON again once the temperature starts rising.
    I experimented with this on one of these mini fridges I bought.
    A significant problem is that it takes a very long time to get to the target temperature, and then it loses it very quickly once the peltier is turned off, suddenly it's got a large amount of heat that it can't get rid of very quickly on the attached heatsink, and the generation of chill has stopped.
    In the video he also shows that the insulation of it is terrible, styrofoam in the walls, but nothing in the door. This might help if it changed, but not a great deal.
    DAB over 2 years ago
    This is another one of those products that fall into the "yes you can build it" category, but "no you should not."
    The efficiencies are just atrocious.
  • battlecoder
    battlecoder over 2 years ago
    Btw one of the things he mentioned in the video is that their efficiency is atrocious. Mostly because they are always ON. I wonder if you could "improve" on that regard if you added a thermoucouple and a low-power micro that would turn the Peltier element OFF when it reaches a target temperature and ON again once the temperature starts rising.
    Maybe for small items the efficiency (when controlled this way) would be more acceptable. Because if it's going to use as much power as a full size fridge the only reason to NOT use a fridge would be the size (and price, but I guess it's always an option to get a second-hand mini fridge for cheap)
  • Matt
    Matt over 2 years ago
    Technology Connections is a great channel; he goes into so much depth on everything he looks at; they're well researched. There are bunch of recent ones on old pinball machines if that floats your boat.
  • beacon_dave
    beacon_dave over 2 years ago
    There's always the WRONGCO brand Solar Powered Tropical Beverage Cooling Mug Slight smile
    /challenges-projects/project14/off-the-grid/b/off-the-grid-blog/posts/solar-powered-tropical-beverage-cooling-mug--blog-1---the-concept
  • battlecoder
    battlecoder over 2 years ago in reply to shabaz
    That's a very clever use for this kind of "fridge", actually.
    shabaz over 2 years ago
    Interesting.. I have a 'fridge like that, but I don't use it for drinks. It's in the shed (i.e. the fan noise isn't an issue there), used for storing solder paste etc., that I wouldn't want inside the home in the normal home 'fridge. It keeps things cool enough for that purpose, but I guess it's non-ideal for drinks storage!
    Also the supplied mains brick is junk (lasts less than a year).. I went through a couple of those on warranty, before just buying a better mains adapter from Farnell. The 'fridge seems reliable, just not the mains brick they supplied. The fan won't last forever of course : (
    • Vote Up +5 Vote Down
