Member's Forum Project Builder - LED Barometer
  • Replies 15 replies
  • Answers 2 answers
  • Subscribers 625 subscribers
  • Views 2051 views
Spencer
Spencer over 1 year ago
Hi
I'm looking to find someone in the UK, ideally the London area, to discuss the possibility of building an LED barometer that I have visually designed. I have a clear understanding of what I would like from the design and have an appreciation of electronics and principles, though lack the practical skills/programming knowledge - if anyone would be intersted in discussing/exploring, I would welcome your response. Thanks, Spencer
  • Spencer
    0 Spencer over 1 year ago in reply to beacon_dave
    Thank you for this.
  • beacon_dave
    0 beacon_dave over 1 year ago in reply to Spencer
    Brett Oliver's DCF77 Analyzer clock might give you some ideas. He has built one into a traditional round wooden case.
    https://www.brettoliver.org.uk/DCF77_Analyzer_Clock_Mk2/Arduino_DCF77_Analyzer_MK2.htm
  • beacon_dave
    If  the case is quite small then another approach might be to use something like a T-Display S3 module
    https://www.youtube.com/watch?v=9vR50HNl3Lo
    https://www.youtube.com/watch?v=AxJ3pf8yh5s
    as this allows you to update the content of the display after construction and give you alternative functionality like displaying a chart of the pressure over time or for adjusting user preferences.
    There are some larger round LCD HDMI displays which could be used with the likes of a Raspberry Pi
    https://www.youtube.com/watch?v=eJBDXjI5Zu4
    and this has the potential of making it more of a multipurpose display - barometer, clock, thermometer, picture frame etc.
    You could also use servo motors moving needles to give you a more traditional mechanical dial look but controlled by modern technology.
  • Spencer
    Probably a dark wood casing I would think - mahogany of some form, perhaps. I like the hidden/diffused LEDs beneath the veneer in the video! Thanks.
  • beacon_dave
    What style of old fashioned case were you thinking of ?
    Traditional 'banjo style' with a round barometer at the bottom and the the vertical thermometer above ? Or perhaps something more minimalist ?
    You can hide LEDs behind thin wood veneer like this:
    /challenges-projects/project14/hacktheholidays/b/blog/posts/led-christmas-tree-advent-calendar
    if you want a plain wood panel that comes to life with modern electronics.
  • Spencer
    0 Spencer over 1 year ago in reply to electronicbiker
    Thanks. :-)
  • Spencer
    Thank you for this information and corresponding links, Dave.
  • Spencer
    0 Spencer over 1 year ago in reply to michaelkellett
    Thank you, MK.
  • beacon_dave
    Perhaps this Arduino project is something similar to what you are trying to do ?
    https://github.com/willemsphoto/Barometer/blob/main/redled-barometer-box.pdf
    Also perhaps take a look at Natasha's series here on how to animate NeoPixel LEDs with a micro:bit
    /learn/learning-center/stem-academy/microbit/microbit-tutorial-videos/b/blog/posts/animating-leds
    0 michaelkellett over 1 year ago in reply to Spencer
    From your detailed description in your reply to  electronicbiker I think your best bet would be to use a string of neopixels controlled by an arduino . You will need a pressure sensor as well.
    The neopixels are cheap and will allow you to have any colour for any LED and pretty much as many as you like.
    Arduinos are good for simple projects with a lot of support on the web. You could make your own control board or use one of dozens of alternatives if you don't fancy the Arduino.
    If you want to go wild you could have a column display of  pressure a bit like a zoomed in mercury barometer.
    https://thepihut.com/collections/adafruit-neopixels
    You can buy neopixels from Aliexpress very cheaply - either loose (requiring assembly onto a pcb) or on tape (ready to connect to a microcontroller.).
