Member's Forum More old mains sockets removed
  • Replies 22 replies
  • Subscribers 548 subscribers
  • Views 1642 views
Workshopshed
Workshopshed 8 months ago
Just swapped out these old sockets. Never seen anything quite like the bottom one. The earth was wrapped around a plate rather than having its own screw terminal.
I searched up the patent.
https://patents.google.com/patent/GB449631A/en
449,631. Plug couplings. ARNOLD, C. L., and DOWSETT, R. W., and MK. ELECTRIC, Ltd., Wakefield Street, Edmonton, London. Fab. 12, 1935, No. 4495. [Class 38 (i)] A socket fitting has a protector 8 that covers the supply sockets 2 and is moved in a plane by the earthing-pin 9a after it has entered its socket 3 so as to uncover the sockets 2. The projection 6a enters the socket 3 below its entry end and a guide 6b slides in holes in the socket 3 and in a plate 4a attached thereto, a spring 7 acting to keep the protector normally in the position shown. In modifications the sliding protector is furnished with a pair of limbs guided on parallel rods and interengaging with a similar pair of fixed limbs supporting the rods, springs being inserted between the limbs, or it may be guided in a channel in the base or in a cap thereon.
    DAB 8 months ago +5
    When I moved into my house about 38 years ago, the first thing I did was upgrade the house for 200 amp service.
  • rsc
    rsc 8 months ago +3
    I worked on a friend's very old house with single fabric-coated solid wires strung between insulators in the basement. every time I touched a wire, some of the wire coating would crumble and fall off.…
  • anniel747
    anniel747 8 months ago in reply to DAB +2
    Deleted
  • acdc90
    acdc90 8 months ago in reply to phoenixcomm
    In Australia and New Zealand with 240v MEN (multiple earth neutral) where each house has its own earth and that is connected to the comon neutral at each house works fine when you grow up with it
    then in most houses before 1970 you had 2 phases ( to share the load ) as it was 3 phase on the pole
    so when looking at 3ph this is 415 between 2 phases
    when it gets scarey is when the neutral becomes disconnected between the house and the pole
    EG turn on 1000w stove element (from phase A) and 150w tv and light on (from phase b)
    so with no neutral the 230v tv gets 415v and dies.
  • acdc90
    another fright is from when we had Hotels with VCR's
    walk into a hotel with 40 rooms to work on aerial system
    aerial was earthed with roof
    there was 1 brand of VCR that had 5m ohm resister between phase and neutral to body
    so you got to wear it when you unplugged the  aerial amplifier
