Member's Forum QUESTION OF THE MONTH : What Soldering tool would you like next to add to your Workbench?
  • Replies 33 replies
  • Subscribers 626 subscribers
  • Views 4181 views
  • poll
  • QOM
vijeth_ds
vijeth_ds over 1 year ago
e14 Question of the Month
Soldering components is a necessary skill for any prototyping maker or engineer. But the right soldering tool you need depends on what you are going to do. A standard soldering station may work for soldering through-hole components to a PCB, but soldering surface mount devices needs a different tool. What are you thinking about purchasing next?
  • COMPACT
    COMPACT over 1 year ago
    Have any of you seen MI:The Final Reckoning film? Have a look at Luther soldering - he is really in need of a new soldering iron tip. His couldn't be more oxidised if one tried. LOL
  • COMPACT
    A solder fountain for wave soldering and mass desoldering, a Hybrid SMD workstation (like ERSA HR 600/2 ) to be able to remove and replace BGAs and alike, and high quality SMD reflow oven.
  • Mr.Hyde
    Mr.Hyde over 1 year ago
    Soldering station variable heat control hot air station and built in power supply for those projects
    shabaz over 1 year ago in reply to rsc
    I've accidentally tried a low-cost tip (it came with a portable USB-C powered soldering iron) with a genuine JBC station, and, maybe it's coincidence, but I experienced a failure of the station eventually. Admittedly it was an old JBC station, and maybe the failure was unrelated.
    Anyway, I've made sure never to accidentally mix the tips with the new JBC station I purchased last year.
    As you say, the JBC tips are expensive : ( however I run them at a reasonably temperature (330 deg C) and with the auto-tip-cooldown, the tips have lasted a decade for me.
    DAB over 1 year ago
    I have everything I need for now.
  • rsc
    rsc over 1 year ago in reply to shabaz
    The JBC is great, but the JBC tips are expensive.  I've seen replacement tips for 1/10 the price, but I'm a little afraid to use them.  Has anyone tried the aftermarket tips?
  • kmikemoo
    kmikemoo over 1 year ago in reply to anniel747
    No.  I used the paste still.  I can certainly give it another try.
  • rsc
    rsc over 1 year ago in reply to anniel747
    Good idea, however, I think the copper wires oxide after a while and the solder doesn't stick as well.  Could probably dip them in an acid bath and re-flux it also - easier just to buy a new roll.
  • rsc
    rsc over 1 year ago in reply to robogary
    I built a soldering station with a microscope and web camera attachment for soldering nano probes in the lab.  It's very useful for the tiny stuff, although it takes up a whole benchtop.  I'm using the JBC soldering station on it.
  • anniel747
    anniel747 over 1 year ago in reply to Andrew J
    Andrew J I never really investigated Hakko, tried a few and never found them worthwhile.
