    • Avnet Boards Community
Ask an Expert Forum Building a Battery using LifePO4 38120 Headways cells
  • Subscribers 287 subscribers
  • Views 431 views
  • battery
  • learning
  • electronics
See a helpful answer?
jamesw2965
jamesw2965 25 days ago
Hey all,
I'm in need of some help building battery using lifepo4 38120 headway cells. They are 3.2v at 8mps per cell. I have (12) Cells. What I need help in is how to connect them so I can get 12v and whatever amperage this becomes.
Can anyone help me with the configuration of the battery?
James
  • Robert Peter Oakes
    Robert Peter Oakes 25 days ago +2
    you wont get 12V exactly, your choice would be 9.6V (3 series batteries) by 32 Amps (4 parallel batteries) in series with 2 more packs resulting in a 3S4P set. or 12.8V (4 series batteries) built with…
    0 Robert Peter Oakes 25 days ago
    12.8V (4 series batteries) built with 3 batteries in parallel for each set resulting in 24 Amps  or 4S3P as they say. you will need a balance charger for it
    0 michaelkellett 24 days ago
    You will need to check the spec of the batteries but one issue with lithium batteries is the greater range of operating voltage than lead acid.
    4 batteries will give you 14.4V when fully charged and just under 12V when discharged.
    The faster you discharge them the less energy you will get out  - this is true for all batteries.
    What load will you be driving ?
     Robert Peter Oakes is right to suggest that you will need a proper balanced charger.
    0 Robert Peter Oakes 24 days ago in reply to michaelkellett
    These are not LiPo, there lifepo4 and are lower voltage even when charging so more important to get the matching charger/balancer
    0 michaelkellett 24 days ago in reply to Robert Peter Oakes
    eclipsebikes.com/.../headway-lifepo4-38120hp-32v-8ah-p-194.html
    3.6V fully charged, 4 * 3.6 = 14.4
    Lithium Ion or polymer closer to 4V so 16V for 4 fully charged.
