    • Avnet Boards Community
Member's Forum What are your Tips for an Organized Workbench? [Ask e14 - Join, Share & Win Competition] September 2025
  • Replies 135 replies
  • Subscribers 534 subscribers
  • Views 8847 views
  • competition
  • organisation
  • question of the month
  • give away
  • workbench
e14phil
e14phil 25 days ago
Calling all makers, engineers, and tinkerers! If your workbench is a masterpiece of order or even a chaotic haven with hidden gems of organisation, we want to hear from YOU!
Join the element14 Community today and take part in our latest “Join, Share & Win” challenge.
Photo Credits: obones michaelkellett Jan Cumps
Got a Tidy Workbench? Turn Your Organizing Skills into a Prize!
Calling all makers, engineers, and tinkerers! If your workbench is a masterpiece of order or even a chaotic haven with hidden gems of organization, we want to hear from YOU!
It’s simple:
1. Register (or Login) for FREE
2. Answer this question by adding a reply / commenting:
What are your top tips for keeping your workbench organised?
3. Be in with a chance to WIN!
We’re celebrating the clever tricks, custom setups, and unique habits that help keep your workspace clean and efficient. Whether it’s colour-coded storage, custom tool racks, or a clever labelling system, we want your insight!
Here’s what you could win:
Arduino Uno R4 Minima
General Terms
What: Win 1 of 3 Arduino UNO R4 Minima
How: Sign up  or Sign in and Comment your best Workbench Organisation Tips below.
When: Before September 30th 2025.
Anything else: Full terms are below, but we must be able to ship to the address in your account.
Entries close September 30th, 2025, so don’t wait!
Get organised, get inspired, and get rewarded with the element14 Community.
Terms & Conditions
 imagePDF
  • rsc
    rsc 1 day ago +8
    PLANO Boxes - I use these fishing/tackle containers for everything. Something I just started is to add a NFC tag on my SD cards to identify software versions for projects. It can hold much more information…
  • rsc
    rsc 14 days ago +6
    I made a nice holder for small screwdrivers and bits, and I can easily move them from desk to desk.
  • kmikemoo
    kmikemoo 16 days ago +5
    Recommendation: The Other Pegboard - for those infrequently used items that don't warrant prime real estate but you still need to have around. Credit to robogary for adding pegboard to the list of workbench…
  • bradfordmiller
    bradfordmiller 24 days ago in reply to beacon_dave
    You do realize that once you pop that in the current number of outlets has increased, thus you need another one.
  • beacon_dave
    beacon_dave 24 days ago in reply to bradfordmiller
    pedants are already covered... Slight smile
    https://cpc.farnell.com/kes/a82/230v-adaptor-16a-16a-4x13a/dp/PL15623
  • colporteur
    colporteur 24 days ago in reply to beacon_dave
    I've never seen these beasts. Is this for above ground cabling like a concert venue or stage setup?
  • beacon_dave
    One work area configuration I had about 20 years ago consisted of full height bookcases against the walls with desks directly in front of them. One shelf was set at the same level as the surface of the desk. This gave a deeper than normal desk which allowed computer monitors to be pushed further back into the bookcase allowing the full surface of the desk to work on. The next shelf was placed above the height of the monitor and could be used for instrumentation, additional monitors, documentation or general storage.
    The desk at the far end of the room was L-shaped and curved and then mirror imaged behind me which effectively gave three work areas accessible by just swivelling the chair through 180 degrees.
  • beacon_dave
    beacon_dave 24 days ago in reply to colporteur
    Yes, indeed. PCE do a black range of connectors specifically aimed at stage use so as not to stand out.
    You can also buy the T-connect with cable entry without the power strip:
    https://cpc.farnell.com/pce/94325000/t-connect-1-in-1-out/dp/PL15612
    and wire it to what you need.
    You can also get this style:
    https://www.rubberbox.co.uk/16a-supply/rub1401b-16amp-power-distribution-box/
  • colporteur
    What gauge of cable between runs?
  • beacon_dave
    Usually either 3x 1.5mm² or 3x 2.5mm² is used.
    dougw 23 days ago
    Organization tips buried in a video - both what to do and what not to do...maybe not the best advice, but decades of hoarding might be worth a giggle....Relaxed
    In case the video doesn't show up, you can see it here:
    https://www.youtube.com/watch?v=wvbjW3c1gow
  • Cliffyd43
    Cliffyd43 23 days ago
    I always have those plastic storage containers that usually are 4 drawers high. All sizes of those 2 big ones under desk, 2 small ontop of desk.
  • beacon_dave
    beacon_dave 23 days ago
    I find it useful for some workstation areas not to have them set up hard against walls. Often equipment has connections at the rear and it's a lot easier if you can get around the back of the workstation area to gain access and be able to see what you are actually doing when patching. This is especially true if your workstation area has overhead shelving or you end up working with stacks of equipment.
    Keeping the workstation off the wall also allows for cable management - longer cables can be left to hang in a loop off the back of the workstation top as opposed to forming a rats nest on the work surface.
