    • Avnet Boards Community
Member's Forum What are your Tips for an Organized Workbench? [Ask e14 - Join, Share & Win Competition] September 2025
  • Replies 131 replies
  • Subscribers 536 subscribers
  • Views 8609 views
  • competition
  • organisation
  • question of the month
  • give away
  • workbench
e14phil
e14phil 24 days ago
Calling all makers, engineers, and tinkerers! If your workbench is a masterpiece of order or even a chaotic haven with hidden gems of organisation, we want to hear from YOU!
Join the element14 Community today and take part in our latest “Join, Share & Win” challenge.
Photo Credits: obones michaelkellett Jan Cumps
Got a Tidy Workbench? Turn Your Organizing Skills into a Prize!
Calling all makers, engineers, and tinkerers! If your workbench is a masterpiece of order or even a chaotic haven with hidden gems of organization, we want to hear from YOU!
It’s simple:
1. Register (or Login) for FREE
2. Answer this question by adding a reply / commenting:
What are your top tips for keeping your workbench organised?
3. Be in with a chance to WIN!
We’re celebrating the clever tricks, custom setups, and unique habits that help keep your workspace clean and efficient. Whether it’s colour-coded storage, custom tool racks, or a clever labelling system, we want your insight!
Here’s what you could win:
Arduino Uno R4 Minima
General Terms
What: Win 1 of 3 Arduino UNO R4 Minima
How: Sign up  or Sign in and Comment your best Workbench Organisation Tips below.
When: Before September 30th 2025.
Anything else: Full terms are below, but we must be able to ship to the address in your account.
Entries close September 30th, 2025, so don’t wait!
Get organised, get inspired, and get rewarded with the element14 Community.
Terms & Conditions
 imagePDF
  • rsc
    rsc 1 day ago +6
    PLANO Boxes - I use these fishing/tackle containers for everything. Something I just started is to add a NFC tag on my SD cards to identify software versions for projects. It can hold much more information…
  • kmikemoo
    kmikemoo 16 days ago +5
    Recommendation: The Other Pegboard - for those infrequently used items that don't warrant prime real estate but you still need to have around. Credit to robogary for adding pegboard to the list of workbench…
  • rsc
    rsc 13 days ago +5
    I made a nice holder for small screwdrivers and bits, and I can easily move them from desk to desk.
  • dang74
    dang74 23 days ago in reply to Jan Cumps
    Interesting way to test the old memory.  I was just like you as far as my record collection goes, but about a month ago I finally put it in alphabetical order.
  • dang74
    dang74 23 days ago in reply to michaelkellett
    I can relate on bad memory.  Recently I opened an old bin up at work and found a PCB from the early 2010s that I don't even remember doing.
  • colporteur
    colporteur 23 days ago
    If you work bench is primarily for electronic builds and repair, my tip would be to start by defining your power requirements. Construct, assemble, install your setup to provide reliable access to all the power types you will need.
    Think about it. You’ll constantly require power. One AC outlet designed to hold two connections but alternating ten connections is a formula for frustration.
    Ensure access to the power is convenient to use. Nothing like continually having to move stuff around to get power only increases frustration. Better yet, let’s drag a few extension cords into the mix.
    The design should include power cables to make connections. Build or buy solid power connection cables. I suggest a three, minimum. People use cables so often that they break. Intermittent cable or repairing the one and only cable while trying to test is a frustration factor times 10.
    Not sure of your power requirement. Sit at a bench and mock up a project or think of repairing something. “I need to plug this into power” typically finds its way into a project. Wouldn’t it be nice if that power were accessible, convenient and reliable?
    The image is a quick connect cable I use for bread boarding power. The 2.5 inch barrel connector comes from a power supply. It can be plugged into devices (no need for wall warts) or plugged into the extension cable that has north & south 2.5mm pins for use on a bread board. The pin arrangement allows the cable to lay flat coming from one end of the board, when plugged into either the north or south power rails on bread board. The set of pins pointing up become a convenient connection point to power other devices from that rail.
    When connect to bread board I secure the pin end it with some electrical tape to ensure it doesn't escape. I have a few of these cables so they tend to stay with a bread board for future use. Got a 2.5 spacing terminal. The pin end fits nicely into the screw terminal also.
    Jan Cumps 23 days ago in reply to colporteur
    Got that covered Slight smile
  • beacon_dave
    beacon_dave 23 days ago in reply to Jan Cumps
    Jan Cumps said:
    Got that covered
    Call that a power strip ?
    genebren 23 days ago in reply to beacon_dave
    Nice power strip.  I was counting up the power strips in my office and I came up with 1-3' strip with 13 outlets and 6 other strips with 4 to 8 outlets.
  • beacon_dave
    beacon_dave 23 days ago in reply to genebren
    It always amuses me when you see an 'award wining' brand new building and from day 1, every office power outlet has a 4-way or 6-way strip attached to it.
    A problem with the standard power strips though is that they don't tend to have a wide enough outlet spacing to accommodate the over-sized wall-warts which have been sized based on the spacing of a standard dual-gang UK 13A wall outlet.
    I've started using 16A T-connects with a 4-way outlets hung off the end of them
    https://cpc.farnell.com/kes/a82/230v-adaptor-16a-16a-4x13a/dp/PL15623
    It allows me the get the exact number of outlets exactly where I need them.
    Jan Cumps 23 days ago in reply to beacon_dave
    (paraphrasing Adam Savage): "the amount of outlets you need is N plus one, where N is the number of outlets you currently have"
  • beacon_dave
    I've got you covered...
    Just pop one of these onto the free end of the T-Connect
    https://cpc.farnell.com/pro-elec/pelb0138/lead-13a-skt-to-16a-plug-1-50mm/dp/PL16356
  • beacon_dave
    and if you turn out really to be a N plus two sort of guy, I've also got you covered...
    https://cpc.farnell.com/pro-elec/pelb0139/lead-13a-2g-skt-to-16a-plg-150mm-35cm/dp/PL16357
